• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Multi width polyline - need inventor solution!!!
    215 Views, 2 Replies
    10-22-2012 09:25 AM
    I am having a problem with trying to come up with a way to create an inventor entity that is like an an autocad multi-width polyline. We make some of our lines in our silk screen as multi-width polylines - see example fig 1. I can't figure out how to accomplish this type of line effect in inventor - see example fig 2. We are actively trying to move from MDT2009 to Inventor aand i can recreate most everything except this multi-width polyline.-
    can someone please let me know if there is a way to do this?
    thank you
    tony t.
    Please use plain text.
    Product Support
    Re: Multi width polyline - need inventor solution!!!
    10-23-2012 09:28 PM in reply to: tonyt
    From reading your description I would think you would need to do this. In the inventor IDW file you would need to select or highlight the view you want to create these Polyline Widths in. Once the view is highlighted in the browser choose the sketch command. This will associate this sketch to this particular view. Then use the project command to project the views geometry you want as “polylines”. Once this geometry is projected you can select it and assign a line weight to it through the drop down.
    Don
    *Pro
    10-24-2012 06:30 AM in reply to: 4donwan4
    To change the weight of selected geometry, just right click and choose Properties.  But to achieve the tapered effect that you show in your attachments, you will have to create the view sketch as Don suggested, then add sketch geometry and hatch solid.  Post something here if you can't figure it out.
