• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    Multi Body Cut Derive Bug in 2012
    174 Views, 5 Replies
    08-17-2012 12:37 PM
    I have a multi body part with an extruded cut through all solids.  Each solid is derived out to its own part.  I edited the extrude feature in the multi body part and removed one solid from the selection set.  The cut was correctly deleted from the solid, but when I open the part its still there.  The only way to make it update correctly is to manually edit the derive  feaure in the part.  Caught it just before it went off for cutting.  2012 SP2, all hotfixes, win7 64 bit.
    Please use plain text.
    Employee
    Re: Multi Body Cut Derive Bug in 2012
    08-19-2012 07:51 PM in reply to: stevec781
    Reproducible on R2012, but it does work fine on R2013 now. Maybe you could have a try on R2013.
    River Cai
    Quality Assurance Team
    Autodesk, Inc.
    Valued Mentor
    08-20-2012 09:16 AM in reply to: stevec781
    Can you please log it for a fix in 2012.  I will not be considering 2013 until SP2.
    Employee
    08-20-2012 08:00 PM in reply to: stevec781
    Hi Stevec,
    Sorry for the inconvenience! Maybe I was lost in this multi body derive workflow yesterday, and today I find it also reproducible on R2013, and maybe there are some additioal steps I made yesterday. It is so curious!
    One issue has been logged against R2012 as 1470436 in our database.
    River Cai
    Autodesk, Inc.
    Product Support
    08-28-2012 11:44 PM in reply to: stevec781
    Hi Steve,
    Please try the attached tool created by Bobvdd to workaround this issue.
    Thanks.
    Rajesh Sivaswamy
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    08-29-2012 09:14 PM in reply to: stevec781
    Hi Steve,
    Please try the attached latest version of the tool that considers derived assemblies also.
    Rajesh Sivaswamy
    Support Specialist
    Product Support
    Autodesk, Inc.
