• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Turbo_Prop_Ross
    Moving sketches between parts?
    115 Views, 4 Replies
    02-08-2012 04:37 PM
    Hey all, a seemingly trivial issue here. I've been making a model plane model in inventor 2012 from imported IGES geometry, and Realised that my sketches were not assigned to any part (and thus can't be lofted). Is there any way of moving the sketches to the newly created part without redrawing everything? I've tried dragging and dropping because it seemed to make sense, but alas, that had no success.
    Distinguished Mentor
    MariaManuela
    Re: Moving sketches between parts?
    02-09-2012 02:12 AM in reply to: Turbo_Prop_Ross
    And about Copy & Paste? Have tested?
    You can also make a Derived Part to take only the sketch.
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    New Member
    Turbo_Prop_Ross
    02-09-2012 02:25 AM in reply to: Turbo_Prop_Ross
    Do either of theose methods copy the location (orientation/offset etc. ) of the sketch?
    ****Sage
    02-09-2012 04:35 AM in reply to: Turbo_Prop_Ross
    Post your file(s) so someone can see what you did.
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    02-10-2012 04:46 AM in reply to: Turbo_Prop_Ross
    Derive is a linked copy of the original file, so the sketch is in exactly the same location and orientation.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2012 SP1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool
