• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Move part along curve with chaindrive in assembly
    153 Views, 3 Replies
    10-04-2012 07:58 AM
    Hi!
    New on this forum, and hope to get some tips how to solve my problem.
    I have two set of chaindrives connected to eachother through a common axle.
    The motor (which is not visible in my assembly) drives the yellow sprocket.
    The two sprockets mounted on the grey axle is attached with a keyway so when the yellow sprocket turns, the two chaindrives turns.
    I want to attach the blue sled on the blue chain, the red sled on the red chain and then rotate the yellow sprocket so both of the sleds moves with their chains (at the same speed/ time).
    The blue sled is going to move a rolled bar (the orange one) on the floor (glass square) a certain length and then the red sled is going to "take over" and continue to move the bar on the floor.
    I want to make sure I´ve got the spacing between the sprockets in the short chaindrive (red) correct so the red sled takes over when the blue sled disapperes under the floor.
    Best regards
    Jonathan
    http://imgur.com/a4d46
    http://imgur.com/AQbFf
    http://imgur.com/j53Qo
    http://imgur.com/RSMrx
    Edit: I use IV 2012, but I also downloaded IV 2013 professional (trial) so I can use the dynamic motion.
    Please use plain text.
    *Expert Elite*
    Re: Move part along curve with chaindrive in assembly
    10-04-2012 09:23 AM in reply to: sjowe
    Wasim Younis http://www.amazon.com
    New Member
    10-10-2012 07:41 AM in reply to: sjowe
    Anyone?
    *Expert Elite*
    10-10-2012 08:03 AM in reply to: sjowe
    See Wasim Younis book - you can get here http://www.amazon.com
    or
    ask your instructor
    or
    attach your assembly here (it isn't easy to describe technique).
