• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Move detail view to a different sheet in Inventor 2009
    1555 Views, 5 Replies
    05-14-2010 01:12 PM
    How can I move a detail view to another sheet in a drawing in 2009? I have only been able to copy the detail and it's parent view to the 2nd sheet and then suppress the parent view on the 2nd sheet so that only the detail view is visible. However, when I go back to the first sheet and try to suppress or delete the detail view, it also deletes/suppresses the detail circle from the parent view.
    Please use plain text.
    *Expert Elite*
    Re: Move detail view to a different sheet in Inventor 2009
    05-14-2010 01:23 PM in reply to: smithme1967
    I forgot how it works in 2009 (might/should be the same) but with 2011 you simply drag the detail view (from the model browser) down to the sheet you want it on. You have to make sure that the sheet that the detail is on (when you start) is the active sheet.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Active Member
    05-14-2010 01:30 PM in reply to: smithme1967
    That worked, thank you!
    Valued Mentor
    Ktelang
    09-23-2010 07:49 AM in reply to: smithme1967
    Thats to both of you this thread helped  :manvery-happy:
    Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
    Inventor 2013 and Vault Basic 2013
    Member
    06-27-2012 08:26 AM in reply to: smithme1967
    Cant get this trick to work in Inventor 2013! It wont allow me to drop thedetail view on the new sheet. Please advice
    Carlos
    Member
    06-27-2012 08:39 AM in reply to: c.vasquez
    Never mind! I was creating the second sheet incorrectly.
