• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    More realistic renders? Another program?
    1027 Views, 15 Replies
    02-23-2012 04:59 PM
    How would I get very realistic renders for my parts? Mostly for metals like aluminium, stainless etc in different colors. Inventor's own materials look very unrealistic. I've seen some very realistic looking parts on the internet (not sure if the CAD program used was Inventor though). Is additional software needed or how people do it?
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: More realistic renders? Another program?
    02-23-2012 05:37 PM in reply to: es12
    3ds Max?
    Valued Contributor
    02-23-2012 06:34 PM in reply to: es12
    Ok I will look into that. If I want animation for my assembly. Should I animate the assembly in Inventor and then change materials and make better renders in 3ds max or is the animation possible to do in 3ds max too?
    JanVarholik
    02-24-2012 02:06 AM in reply to: es12
    For creating realistic rendered images you should take a look at Inventor Studio. This a package within Autodesk Inventor. You can find some good tutorials on youtube.
    *Expert Elite*
    MariaManuela
    02-24-2012 02:26 AM in reply to: es12
    To get quicly and very nice realistic images use Autodesk Showcase. Its ease and powerfull. Look at suites to undestand if you have Showcase and 3DMax.
    Showcase example
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    *Expert Elite*
    02-24-2012 05:42 AM in reply to: MariaManuela
    With enough time spent modifying/playing with the Inventor colors you can get some pretty darn realistic renderings using the new raytracing option alone.. There is almost NO need for studio anymore. And if you have been on subscription you now have access to showcase as well as 3ds max. Start by spending a little time in Inventor and see where you can get with it. I'm very happy with what I can do with Inventor now (raytracing alone) and am very excited to see what 2013 has to offer.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Contributor
    02-24-2012 09:03 AM in reply to: es12
    Thanks guys. I will play more with Inventor's own material options first before trying the other methods. I will update here how it goes.
    Update: Showcase looks very nice from what I saw in youtube and there's also 30 day trial for it so I will check that out for sure too. If I want to make animation for my assembly (about 1min long), do I have to make the animation in Inventor or is it possible to just assemble in Inventor and then make the movement in Showcase?
    *Expert Elite*
    MariaManuela
    02-24-2012 10:23 AM in reply to: es12
    Hi again!
    Autodesk Showcase its amazing!!!!! Very very ease.
    In Showcase you create scenes from an Inventor file, complete with Materials, Shots, Alternatives, Storyboard, and animated Constraints.
    http://usa.autodesk.com/adsk/servlet/limage?siteID=123112&imageID=16831153&id=6834016
    Maria Manuela Pinho
    Valued Contributor
    02-25-2012 06:20 PM in reply to: es12
    Downloaded the 64bit trial version for my 64bit Win7 Home Edition. I played with it and the software seems pretty easy to use. After a hour or two of testing I quit it and started Inventor and the graphics in the Inventor had changed. I used Inventor with "compatibility" setting and it always used the highest graphics. Now it always uses the lowest graphics. In "performance" mode now the colors are normal but the edges of the part look like crap and with the "compatibility" mode it changes the part color to almost white.
    I uninstalled the Showcase and reinstalled Inventor but that didn't help. I had planned to reinstall my OS so I made new clean Win7 install and downloaded all the latest drivers. Same problem with the Inventor. I have no idea what happened.
    I have integrated graphics card btw, but that shouldn't make any difference since the softwares worked fine before.
    *Expert Elite*
    blair
    02-26-2012 01:25 PM in reply to: es12
    Just try doing a system re-boot. There is a screen switch in the DirectX when using Showcase, possible after exiting Showcase it didn't fully switch back because of your integrated graphics card.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
