Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
More RAM or new video card?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My machine is really slow even though my models are quite small and a couple of times a day I get a message about windows switching to virtual memory. Its as if Inventor doesnt release the RAM when I close files.
The machine is 64 bit with 8GB Ram and a Quadro FX 570 card.
Which would give the most benefit, more RAM or a better card?
Re: More RAM or new video card?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should give priority to RAM then Graphics Card.
If 64-bit system you should consider at least 8GB (minimum). Adding more RAM to your system will provide better performance and capacity.
Minimum for large assemblies:
Win7 x64 (Ultimate, Enterprise or Professional)
Quad or Six core Intel Xeon processor
12 GB or more system RAM
DX 11 level graphics card with 2 GB or more video RAM
At least 1 TB of hard disk space
Autodesk certified graphics hardware: http://usa.autodesk.com/adsk/servlet/cert?siteID=1
Recommended for large assemblies:
Dual Six core processor (i.e. 12 cores total, hyperthreading not recommended because
Inventor does not take advantage (except Studio rendering))
24 GB or more system RAM
DirectX 11 level graphics card with 2 GB or more video RAM (CAD workstation-class
graphics card )
Two (or more) 1 TB hard disk drives, SATA, SAS, Ultra 160 and Ultra 320 SCSI, SSD, RAID 0
or 1, 7200 RPM or better
More info here: http://wikihelp.autodesk.com/Inventor/enu/2012/Hel
Application Enginner
Cadtech.Asidek | Autodesk Gold Partner
http://cadtech-asidek.blogspot.com/
www.cadtech.pt | www.cadtech.es | www.asidek.es
Autodesk Inventor Professional 2013
Windows 7 Professional 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is a crappy video card though (only 256Mb onboard ram)..
8M of regular RAM should be enough if your models are really small like you say.
You can easily monitor ram usage.
I'd say video card first in this case
Get a decent Nvidia Geforce card with 512Mb "minimum" of onboard video ram.. I'd shoot for 1G
Of course you didn't mention anything about your processor or hard drive (if you are saving locally)
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Regarding the comment about Inventor not releasing RAM when the file is closed, in Application Options - File, do you have 'Quick File Open' at the bottom of the page selected ? If so inventor will cache the last assembly in memory.
Regards
Martin
PDSU 2014 RTM
Windows 7 64bit, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 580GTX Graphics (Diver 310.70)
256GB SSD OS, 80GB SSD working folder
Space Pilot
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Use Memprobe.exe to obtain detailed information on how your system RAM is being used. This utility is located in C:\Program Files\Autodesk\Inventor <version>\Bin\. When working with Memprobe.exe, add the Inventor Working Set and the System Working Set then compare to the Hardware value.
There are many many possible things to do to improve performance..The document that i attach in my first post show many ways to optimize performance.
You should also enable Performance option in Hardware application options.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the replys.
Performance option was checked but so was quick file open so I unchecked it to see what happens.
When I say the model is small I mean 326 parts, but lots of deriving, lots of frames. I often wait for around 1 min just waiting for the mouse to come back to life. Sometimes just zooming in will freeze it for a while.
I use Kasperksy with inv in the trusted set, and have nothing else open, not even email. I check it every couple of hours and shut it down. Stand alone station so no vault, no network. So something is way off.
Chip is Intel Duo Core E8400 3.0GHz. Not sure about hard disk specs but it was a good one at the time. OS is XP64 SP2.
Inv is installed in C partition and all files are on R partition.
The card was a result of this machine originally being for solid works. Back then I was told that RAM was less important for OpenGl. Solidworks went well on this machine and the graphics were nice. But in Inventor I cant even get a shadowed display so I guess Ram is more is important for DirectX. The card supports both but I cant find a setting so I assume that inventor sets the card mode??
Unfortunaley I have 4 x2GB ram so I would have to buy the whole 16GB to upgrade so I might start with a new card. Thinking if it is card then I can spend some more and go for a GTX 590 if my board will take it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
stevec781 wrote:When I say the model is small I mean 326 parts, but lots of deriving, lots of frames. I often wait for around 1 min just waiting for the mouse to come back to life. Sometimes just zooming in will freeze it for a while.
The modeling methodology is also very important.
I do not know if you are already using......but follow some tips:
You use sub-assemblies? Must use (this way you will have to give fewer constraints)
You create assembly patterns in the first assembly level? Should NOT use
You use Level Of Details? Must use
You use Substitutions? Must Use
You use Adaptativity? Must disable
etc...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
MariaManuela wrote:The modeling methodology is also very important.
For thousands of parts absolutely but for a few hundred? I shouldnt think such small models would have any restrictions, but
Sub assemblies - yes
Patterns - in part features yes, assembly components NA.
LOD - no. Not practical
Representations - yes
Substitutions - no not practical
Adaptivity - rarely but sometimes
Generally I use skeletal technicques based on common origin so very few mates, but most parts have master parts derived into them as composites.
To add a simple coincident constraint takes about 5 seconds of hard disk scratching before anything happens.
I have just won a much larger project and am concerned that Inv wont be the right tool for the job but need to make sure its not my hardware first.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We have a some customers working with big and complex assemblies, the last one where i've been working works with more then 40.000 componentes. Who? Sure with good hardware but more with large assemblys tecniques.
So in your case has to work.
Make sure you have your sistem updated. All recent drivers, service packs....etc
I read somewhere that this anti-virus updates every day. Does NOTaffect the performance??
Install the latest drivers\firmware. (By Autodesk WikiHelp)
• Hard Disk Drive
• Hard Disk Controllers
• CD-ROM|DVD Player\CDR\RW drives
• Monitors
• Network Card
• Sound Card
• Keyboard
• Mouse
• 3D mouse (SpaceMouse, SpaceNavigator, SpacePilot, etc.)
• Any other peripheral device connected to the machine (e.g. Printer, Camera, Digitizer, etc.)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got memprobe running and task manager. Its showing 5GB of ram available. When I rotate the screen, CPU usage goes to 60%, ram doesnt move, when I rebuild, CPU usage goes to 80%, the page file seems to be being used and the ram barely moves. Just moving the mouse around and highlighting takes cpu to 70%.
So it doesnt look like more ram will help if its not being maxed out now. I dont understand why the page file is being used at all when there is ram available.
