• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Modelling bicycle gears
    368 Views, 5 Replies
    11-05-2012 07:18 AM
    My question:
    How can I create bicycle gears that have different numbers of teeth but all have an intertooth distance (distance between the teeth centres) of 12.7mm?
    My attempt at a solution and problems encountered:
    I made a bicycle gear by patterning a small circle around a large circle then trimming lines (see attached sketch), but this method requires me to estimate the diameter of the large circle before patterning and then keep modifying this slightly until I get an intertooth distance as close as possible to 12.7mm. So I can't get exactly 12.7mm. In my sketch I have labelled this intertooth distance I refer to by construction lines.
    Thanks in advance.
    Please use plain text.
    Re: Modelling bicycle gears
    11-05-2012 07:25 AM in reply to: AdskInv
    Why not use the Roller Chain Spocket Design Accelerator?
    11-05-2012 07:34 AM in reply to: JDMather
    In any case, I would not create a complex sketch like that.
    It is better to pattern features than to pattern sketch.
    If you Right Mouse Button - Show All Constraints - you will see that there are too many constraints that would have to be solved.
    Active Member
    11-05-2012 07:57 AM in reply to: JDMather
    The shape of the teeth is not the shape I want to use. I also need to model a specific chain type. Though I could try and edit them to suit my needs.
    11-05-2012 08:17 AM in reply to: AdskInv
    AdskInv wrote:
     I also need to model a specific chain type. .
    What is the chain type?
    You could examine the attached file and alter it (or start from scratch) using the basic technique.
    Active Member
    11-05-2012 08:46 AM in reply to: JDMather
    A Shimano CN HG94 chain. It's a very narrow chain and is also not symetrical. I might just pick the narrowest chain with 12.7mm pitch that the design accelerator offers.
    Thanks.
