• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    Modelling a cable
    252 Views, 4 Replies
    01-04-2013 02:36 AM
    I was wondering the best way to model a steel tensioner cable in Inventor. The assembly I have designed is of a cable fixed between two brackets which are fastened on two structural beams. I am looking accurately model the cable attachment on the brackets. My inital thought would be to extrude the length of cable through a pre-defined path between the bracket fixing holes however this would not represent a 'true life scenario'. Any suggestions would be appreciated.
    Product Design Suite Ultimate 2013
    64-bit HP Z400, Intel Xeon W3550 3.07GHz
    12.0GB RAM, ATI FirePro V4800 (FireGL)
    Please use plain text.
    *Pro
    Re: Modelling a cable
    01-04-2013 03:42 AM in reply to: Anthony
    Post a picture of what you're trying to accomplish.  You call it a tensioner cable, which leads me to think that it will mostly be straight (i.e. under tension), so I'm not understanding the "true life scenario".
    01-04-2013 04:21 AM in reply to: Anthony
    Anthony wrote:
    ...extrude the length of cable through a pre-defined path
    That describes Sweep, not Extrude.
    Anthony
    Re: Modeling a cable
    01-04-2013 05:36 AM in reply to: sbixler
    Hi, thank you for your reply. Please see attached screenshot of the intended result. The cables will be under tension as you have stated and will therefore will be represented straight, I may be asked to produce flexible cable as well for further design development which is why I asked the original question. Thank you.
    rhasell
    01-06-2013 09:59 PM in reply to: Anthony
    Hi
    The Cable is not the problem here, simple extrude/sweep, the issue is the attachments.
    You will need to model up the fittings and tensioner (Shackles, rigging screws, Swage ends, etc) Have a look at "VanBeest" there are a lot of fixings there (All green pin lifting equipment), the rest you will have to look at grabcad, and do your own modeling.
    This will give you a better representation of the cable.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
