• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Mears, Brian
    Model curved panel to show flat in drawing
    43 Views, 8 Replies
    11-05-2002 03:22 AM
    I need to model a curved panel (.125 sheet
    plastic), but I need to show it flat in the drawing.  How could I go about
    doing this in Inventor?
    FYI... In MDT, I knew of no easy way to do this...
    I modeled the part curved (as it will be in the assembly) and drew it in 2D
    (flat) on the drawing.  So, if I updated the model, I had to remember to
    manually update the drawing.
    I hope there's a better way in Inventor.
    We have to do this quite often. Thanks...
    Brian
    Please use plain text.
    *Keller, Kent
    Re: Model curved panel to show flat in drawing
    11-05-2002 03:59 AM in reply to: *Mears, Brian
    Brian
    Is it curved in more than one direction? If not just use the SM tools.... but I am
    guessing it is?
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "Brian Mears" wrote in message
    news:9745A70244A98CE40CDDCCDAC089A5DC@in.WebX.maYIadrTaRb...
    > I need to model a curved panel (.125 sheet plastic), but I need to show it flat in the
    drawing. How could I go about doing this in Inventor?
    > FYI... In MDT, I knew of no easy way to do this... I modeled the part curved (as it will
    be in the assembly) and drew it in 2D (flat) on the drawing. So, if I updated the model,
    I had to remember to manually update the drawing.
    > I hope there's a better way in Inventor. We have to do this quite often. Thanks...
    > Brian
    *Caldwell, Larry
    Re:
    11-05-2002 04:10 AM in reply to: *Mears, Brian
    It will fold a curve in two directions as well.
    ~Larry
    "Kent Keller" wrote in message
    news:4584393921D88015E64FFA5E132B7F9D@in.WebX.maYIadrTaRb...
    > Brian
    but I am
    > guessing it is?
    > Kent
    it flat in the
    curved (as it will
    updated the model,
    often. Thanks...
    > > Brian
    *Keller, Kent
    Re:
    11-05-2002 04:50 AM in reply to: *Mears, Brian
    Larry
    Are you saying it can fold and flatten something that stretches in more than one
    direction? If so ...how? I am hoping you haven't shown me this recently and my steel
    trap of a mind let it slip through
    Kent
    "Larry Caldwell" wrote in message
    news:55FE33C9B7F6693FFF8E34DB1C780B48@in.WebX.maYIadrTaRb...
    > ~Larry
    *Yeandle, Laurence
    Re:
    11-05-2002 05:39 AM in reply to: *Mears, Brian
    Laurence,
    > ~Larry
    > > Brian
    tools....
    > but I am
    > > guessing it is?
    > > Kent
    show
    > it flat in the
    > curved (as it will
    > updated the model,
    > often. Thanks...
    > > > Brian
    *Caldwell, Larry
    Re:
    11-05-2002 05:52 AM in reply to: *Mears, Brian
    I put an example in CF ... but I'm sure you already know about it.
    ~Larry
    news:E136006DF132F8DACA2244ACC5A09B0E@in.WebX.maYIadrTaRb...
    > Larry
    than one
    and my steel
    > Kent
    > > ~Larry
    *Caldwell, Larry
    Re:
    11-05-2002 06:00 AM in reply to: *Mears, Brian
    I put it under subject Fold ... I added one folded the other way too.
    ~Larry
    > Larry
    than one
    and my steel
    > Kent
    > > ~Larry
    *Howard, Jeff
    Re:
    11-05-2002 08:31 AM in reply to: *Mears, Brian
    I think Kent was referring to a compound curvature (which IV won't do)?
    *Keller, Kent
    Re:
    11-05-2002 10:17 AM in reply to: *Mears, Brian
    Thanks Jeff Man I love getting old.... couldn't come up with compound
    curvature.
    Kent Keller
    http://www.MyMcad.com/KWiK/Mcad.htm
    "Jeff Howard" wrote in message
    news:7D7C428C61CAF842B2628E1D3F3DDD69@in.WebX.maYIadrTaRb...
