• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Mitering tube
    187 Views, 5 Replies
    01-04-2013 06:39 AM
    I am needing to create some new parts with miters that will reflect how they will be cut on our tube laser.
    I have attached a part sample that someone else has created. I have no idea how to change this into a part that will work for me, so I'm wanting to start brand new.
    I am needing the surface of the miter to be perpendicular to the material all through the miter.
    How would I accomplish this?
    I appreciate your help with this.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
    ACAD Mechanical 2013
    Please use plain text.
    Re: Mitering tube
    01-04-2013 09:58 AM in reply to: sps_cad_guy
    The part you posted has two different types of miters.
    For the straight through cut type use Split with an angled sketch line (or a workplane) to cut the part.
    For the perpendicular to material face (I assume you will be creating from flat and then folding up) Extrude the profile as a surface body rather than solid body, then Split or Trim the surface as above and then Thicken.
    Attach your attempts at these two techniques if you can't figure it out.
    *Pro
    Re: Mitering tube
    01-04-2013 10:42 AM in reply to: sps_cad_guy
    Here's my attempt.  JD, yours still needs some trimming if it is to be used for a real miter, since there's a chunk protruding into the 45° face:
    Valued Contributor
    Re: Mitering tube
    01-04-2013 11:59 AM in reply to: sbixler
    I have never worked with solid bodies or surface bodies, so I went with sbixlers part.
    I think I have it close, but when I mirror the second half, a couple of the cuts don't
    mirror over.
    What am I doing wrong?
    Thanks again for the help.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
    *Pro
    Re: Mitering tube
    01-04-2013 12:08 PM in reply to: sps_cad_guy
    In the Mirror feature, choose "Mirror a solid" instead of "Mirror individual features".
    Valued Contributor
    Re: Mitering tube
    01-04-2013 12:11 PM in reply to: sbixler
    Worked perfectly! Thank you so very much.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
