• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Hoder, Dave
    Miter Folds
    119 Views, 15 Replies
    02-12-2003 06:05 AM
    Has anyone figured out how to do a miter fold yet? If you don't know what
    that is, picture this:
    Take a strip of material say 4"x48"x1/2", chamfer the 2 short ends @ 45 deg,
    cut 3 45deg v-grooves at equal spacing & leave .030" material at the bottom
    of the groove. Now fold the machined part into a rectangle. Maybe one of you
    sheet metal gurus can help me here.
    Thanx, Dave
    Please use plain text.
    *Keller, Kent
    Re: Miter Folds
    02-12-2003 06:48 AM in reply to: *Hoder, Dave
    I would think it could be modeled without to much hair pulling, but I doubt you will be
    able to unfold it.
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "Dave Hoder" wrote in message
    news:963038B2A0AF04CE775DF5DE9F07DA28@in.WebX.maYIadrTaRb...
    > Thanx, Dave
    *Hoder, Dave
    Re:
    02-12-2003 07:37 AM in reply to: *Hoder, Dave
    I need to show it as one part (with the original part size) in the BOM &
    unfold it for machining. Right now I'm faking it by making a drived part
    from a dummy unfolded assy & hiding the separate parts in the Parts List.
    This won't be a good idea though as soon as we start pulling data directly
    from assemblies. Any ideas?
    *Bliss, Charles
    Re: Miter Folds
    02-12-2003 11:46 AM in reply to: *Hoder, Dave
    Create flanges using the offset option. make the offset longer then the
    flange width. This will leave large gaps between your flanges. Use the
    corner tool to close the flanges. This will give you a mitered corner.
    I have placed an example in Customer Files.
    >Thanx, Dave
    *Keller, Kent
    Re:
    02-12-2003 01:12 PM in reply to: *Hoder, Dave
    I could easily be wrong, but I don't think that is what he is after. The
    words 45deg v-groves and Machined parts makes me think he wants a weakening
    grove to make the fold with.
    Kent Keller
    http://www.MyMcad.com/KWiK/Mcad.htm
    "Charles Bliss" wrote in message
    news:3E4B1502.5000604@cbliss.com...
    deg,
    bottom
    *Hendey, Matt
    Re: Miter Folds
    02-12-2003 08:38 PM in reply to: *Hoder, Dave
    Can you post what you have in CF?
    Matt
    *Keller, Kent
    Re:
    02-13-2003 01:11 AM in reply to: *Hoder, Dave
    Matt
    If you are talking to Charles... He did! 8^)
    Kent
    "Matt Hendey" wrote in message
    news:f1431d6.4@WebX.maYIadrTaRb...
    > Matt
    *Hendey, Matt
    Re:
    02-13-2003 03:10 AM in reply to: *Hoder, Dave
    No to Dave, Sorry. I'm interested in what he is trying to do. I tried
    creating the part from the description he gave but if I got it right, I
    can't see the reason for building a part that way. No that there isn't one.
    Matt
    "Kent Keller" wrote in message
    news:1B117C461A3FF93F56B7ACC5468940BB@in.WebX.maYIadrTaRb...
    > Matt
    > Kent
    > > Matt
    *Hoder, Dave
    Re:
    02-14-2003 12:46 AM in reply to: *Hoder, Dave
    The part is in CF called Miter Fold. (I just made an example shape, not a
    sheet metal part) This is a common manufacturing process in the furniture /
    woodworking industry where we are working with a piece of wood covered with
    a colored paper. We cut thru the wood & leave the paper, then fold the whole
    thing together. This makes for a cleaner seam & less assemby time.
    Thanks for having a look.
    *Caldwell, Larry
    Re:
    02-14-2003 12:53 AM in reply to: *Hoder, Dave
    I did one of those by ... cheating? ... making a face that would bend then
    add the rest in an assembly because it needed to be shown both flat and
    folded.
    ~Larry
    news:F82FB0D513739B07DFE1A95A4327C751@in.WebX.maYIadrTaRb...
    with
    whole
