• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    gcross
    Missing parts in IPN file-2012 Bug ?
    226 Views, 5 Replies
    03-13-2012 09:34 PM
    A couple parts that I moved from one subasy to another in an IAM are not showing in the associated IPN browser at all. Yet they are visible in the edit window & look as if they have tweaks applied.  I can click on & highlight them but there is no sign of them in the browser at all.
    The parts are definitely in the browser of the IAM file though.
     Is this a known bug?
    Gary
    Inventor Suite 2013 Ultimate
    Please use plain text.
    Employee
    Re: Missing parts in IPN file-2012 Bug ?
    03-14-2012 01:28 AM in reply to: gcross
    Could you reproduce this issue on a simplified dataset? Can you attach the simplified or the original dataset for more investigation?
    Csaba
    gcross
    03-15-2012 07:14 PM in reply to: csaba.stupak
    Csaba,
    I don't know how to duplicate the problem not knowing what causes it.
    The zipped original files are 7 MB. Where can I upload the data set for you? I would prefer not to make it public.
    Thanks.
    Gary
    Employee
    stanislav.sedlak
    03-21-2012 07:20 AM in reply to: gcross
    Hi Gary,
    I'm Stanislav and I known about this problem from Csaba.
    So please send me this zipped file to my e-mail stanislav.sedlak@autodesk.com, I will take a look at this.
    Stanislav
    01-14-2013 11:46 AM in reply to: gcross
    Inventor 2013
    I know this thread is not current, but it is exactly the issue Im trying to address.
    I have a large assembly that I do not want to "re-create" the .ipn/ .idw
    It does not happen normally, but  has more than once.
    After copying the design of a given assembly, I have replaced one assembly with 3 smaller sub assemblies in the .iam.
    My procedure is as follows:
    Locate sub-assembly in Browser/ Expand/ Highlight all 3 components within the assembly.
    Drag them up in the hierarchy(No to check out) delete the original assembly without changes.
    Replaced component on each of the 3 (sub) assemblies with desired (smaller) assemblies.
    Sort Browser
    update Bill of Materials
    save.
    Open .ipn
    The assemblies that were modified highlight properly in the window but do not exist in the assembly browser
    and there are idividual parts from those "modified" assemblies that appear to have been orphaned by the tweaks.
    Ive had assemblies go awry in the .ipn before after replacing components or similar, but I can usually delete the problematic tweaks and recreate them without having to delete the original .ipn and re-create the entire drawing(s).
    The modified assemblies are moved as if there are tweaks applied but if you switch the browser to tweak view and hover over the indivdual tweaks, no tweak exist for the modifed assemblies either.
    Our only option has been to delete the original .ipn / .idw and re-create them. (undesirable)
    Is there some way to refresh the browser?
    Has my procedure created the issue?
    Any thoughts are appreciated.
    Thanks!
    Windows 7 Pro SP1 (x64)
    Intel I7 CPU
    12GB ram
    ATI FirePro V5800
    IV 2013 SP1.1
    Autocadd Mechanical 2013 SP1
    Vault Basic 2013 SP1
    Distinguished Mentor
    -niels-
    01-14-2013 11:19 PM in reply to: TomAllen
    Just adding a link to my topic about what i think is the same problem.
    http://forums.autodesk.com/t5/Autodesk-Inventor/Unable-to-expand-assembly-in-presentation-ipn/m-p/37...
    Didn't know this older topic existed, but hope this problem will get some more attention and maybe a solution.
    Using IV2013 Pro SP1.1, Win7-64bit
