Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Mirror trouble
- Highlight
- Email to a Friend
Hello Inventor users!
I have a problem with the mirror feature. As illustrated in the 4 pictures below, I first create a part, then try to mirror it and get a part, that is not mirrored at all. It's rather just copied and shifted.
So what could be the problem here? Anybody had similar issues?
Best regards, pb
edit:
Apparently, you can't mirror modified parts from the content center correctly... It works with parts that I created entirely myself. I can understand that with bolts and nuts from the content center, but L-shapes?
Re: Mirror trouble
- Highlight
- Email to a Friend
If parts still reside within the CC (most likely they are Read Only) you need to save the parts as Custom when you are creating them from the CC.
Mirroring within a IPT will create a mirror of the source along with the mirror. If you want to create a RH part and then mirror it to have a LH part as well, look at Derived function. Create your RH part, save and close it, then start a new part, close the sketch and return to the Feature level. Then select Derive, it will ask for the source part(your RH part), select this from the file select window. Then within the Derive window there is a box that needs to be selected for Mirror. This will then produce your LH part.
If the link is maintained, any changes to the base part (RH part) will be updated to the LH (mirrored) part.
Using the Mirror function within the IPT environment is really only good for designing a IPT that one side/half is a mirror of the other side.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 320.18
SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
Re: Mirror trouble
- Highlight
- Email to a Friend
In Step 3, you show the dialog box with "Reuse Standard Content and Factory Parts" checked. What happens if you uncheck that?
Re: Mirror trouble
- Highlight
- Email to a Friend
Thanks a lot. Inserting with the custom option in the content center seems to do the trick.
I still find it a little odd, that the CC part apparently will mirror correctly, while the modifications on the part will not...
pb
