• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Mirror command?
    370 Views, 11 Replies
    10-24-2012 10:22 PM
    In the attached file is an illustration of a vise base. What is an expedited technique to duplicate the padeyes seen in the isometric view to the other side? Thank you in advance
    Will
    Please use plain text.
    Valued Contributor
    machiel.veldkamp
    Re: Mirror command?
    10-25-2012 03:01 AM in reply to: wmd2
    You need a work plane in the center of the model you're working on.
    You can either do that by editing your first exstrusion and place that one in the center (then you're done (exept the model freaks out..)) or, you can make a new work plane by pressing ']' and selecting the two oposite sites of your model, then a work plane will be placed in the center of those to planes.
    Then you have a usable workplane that you can use.
    ___________________________
    Inventor 2012 lastest service pack
    RAM: 16GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
    Video: NVidia Quardo 2000 / HDD: 15.7K
    Windows 7 Pro 64-bit
    Re: Mirror command?
    10-26-2012 12:52 PM in reply to: machiel.veldkamp
    In fact it did freak out. The attachment shows the following run time error; R6025 pure virtual function call
    Re: Mirror command?
    10-26-2012 05:27 PM in reply to: wmd2
    Attach ipt files, not pictures.  Can't edit pictures or see clearly what you did in pictures.
    Doesn't look to me like you have created correct mirror plane as shown in previous response.
    Inventor Professional 2014 Edu 64-bit
    Re: Mirror command?
    10-26-2012 05:28 PM in reply to: JDMather
    Your Sketch1 is not constrained or placed with a logical orientation to the origin.
    I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    Re: Mirror command?
    10-26-2012 05:33 PM in reply to: wmd2
    Line not vertical?
    Line has unmanufacturable dimension
    Extra horizontal line at bottom.
    Horizontal line at top not dimensioned.
    Re: Mirror command?
    10-27-2012 04:29 AM in reply to: wmd2
    Attached please find the sketch in its current form. Thank you
    Re: Mirror command?
    10-27-2012 10:11 AM in reply to: wmd2
    Why?  Did you attach the correct file?  You didn't fix any of the issues in this file and there is no mirror plane?
    Re: Mirror command?
    10-27-2012 10:20 AM in reply to: JDMather
    You are very responsive. And your responses are very anticipatory. But that's good
    Re: Mirror command?
    10-27-2012 10:56 AM in reply to: wmd2
    Extrusion1 should be mid-plane (Symmetric).
    Sketch2 is not constrained.
    Sketch7 is not constrained.
    Sketch9 is not constrained.
