Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the attached file is an illustration of a vise base. What is an expedited technique to duplicate the padeyes seen in the isometric view to the other side? Thank you in advance
Will
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need a work plane in the center of the model you're working on.
You can either do that by editing your first exstrusion and place that one in the center (then you're done (exept the model freaks out..)) or, you can make a new work plane by pressing ']' and selecting the two oposite sites of your model, then a work plane will be placed in the center of those to planes.
Then you have a usable workplane that you can use.
___________________________Inventor 2012 lastest service pack
RAM: 16GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
Video: NVidia Quardo 2000 / HDD: 15.7K
Windows 7 Pro 64-bit
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In fact it did freak out. The attachment shows the following run time error; R6025 pure virtual function call
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attach ipt files, not pictures. Can't edit pictures or see clearly what you did in pictures.
Doesn't look to me like you have created correct mirror plane as shown in previous response.
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your Sketch1 is not constrained or placed with a logical orientation to the origin.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20Universit
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Line not vertical?
Line has unmanufacturable dimension
Extra horizontal line at bottom.
Horizontal line at top not dimensioned.
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attached please find the sketch in its current form. Thank you
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
wmd2 wrote:Attached please find the sketch in its current form. Thank you
Why? Did you attach the correct file? You didn't fix any of the issues in this file and there is no mirror plane?
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Mirror command?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Extrusion1 should be mid-plane (Symmetric).
Sketch2 is not constrained.
Sketch7 is not constrained.
Sketch9 is not constrained.
