• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Minimum dimensions needed
    146 Views, 6 Replies
    04-03-2012 12:57 PM
    All of the sudden after I sketch a rectangle i need 8 dimensions instead of 4.  how do I get it back to only needing 4?
    Please use plain text.
    Valued Contributor
    schae235
    Re: Minimum dimensions needed
    04-03-2012 01:03 PM in reply to: sweeneym
    I'm only guessing here but I think you had one of the end points constrained to the origin.
    You can easily add a coincident constraint on one of the corners
    OR as I prefer add horizontal and vertical constraints to the center marks of the lines of the rectangles.
    INV 2012 SP1
    Windows 7 64 Bit
    ATI FirePro V5800
    14.0 GB RAM
    Member
    04-03-2012 01:10 PM in reply to: schae235
    No I always draw teh rectangles like this then add 4 dimensions the horizontal and vertical overall lengths then distacnce to center. Now it wants me to constrain the 2 vertical and 2 horizontal lines. as well as dimensioning the lines.
    04-03-2012 01:13 PM in reply to: sweeneym
    Did these get turned off?
    Member
    04-03-2012 01:28 PM in reply to: Accudyne1
    Accudyne1, I couldn't reall read your screen shot here but with me switching back and forth from classic to ribbon interface style the problem was fixed.
    04-03-2012 01:29 PM in reply to: sweeneym
    The actual image was attached also, but glad you fixed it.  I am guessing it was constraint inference/persistence.  They must have gotten toggled off at some point.
    Tony
    Member
    04-03-2012 01:32 PM in reply to: sweeneym
