• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Migrating from Inventor 2011 to Inventor 2010
    109 Views, 4 Replies
    09-04-2012 11:40 AM
    Hi, I have generated a mold assembly on Inventor 2011, but I have to migrate these files to Inventor 2010, because is the version I use in my job, IT manager uninstalled Inventor 2010 and installed 2011 version, I worked on it but then back to work on 2010 version. Is there a way to do it?
    Please use plain text.
    *Pro
    jletcher
    Re: Migrating from Inventor 2011 to Inventor 2010
    09-04-2012 11:43 AM in reply to: JavZaMa
    no..
    Step file is the only way to go backwards..........
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    09-04-2012 11:50 AM in reply to: jletcher
    ok :smileysad:
    Do I have to do it with the Content Center Files too???
    *Pro
    jletcher
    09-04-2012 11:54 AM in reply to: JavZaMa
    I do not know if they was made with 2011 and saved but I do know that CC parts are not migrated through autodesk. So some of the CC files are in 2008 format.. You may get lucky :smileyhappy:
    James Letcher
    Valued Mentor
    jclaidler
    09-05-2012 06:29 AM in reply to: JavZaMa
    Content Center files are 'ipt' files, and also are not 'backward compatible'.
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
