Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Midplanes in assemblies
- Highlight
- Email to a Friend
I'm a little confused. After reading the documentation for IV 2013, I'm not sure if it's possible to create a midplane between parallel faces of two different parts or not. I've tried using the workplane buttons in both the 3D Model and the Assembly tabs with no joy.
Can someone please clarify?
Thank you.
Windows 7 64-bit
Intel Core 2 Quad Q9300 2.5GHz
8 GB RAM
Nvidia GeForce 8800 GT
Re: Midplanes in assemblies
- Highlight
- Email to a Friend
You would need to use a parameter
If the one plane is constrained to another work plane, you should be able to use the paramter ID / 2 as your mid distane.
Work-Plane 2 is contrained from Work-Plane 1 by contraint "d26". You should then be able to us "d26/2" for your distance when you create your mid Work-Plane
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
- Highlight
- Email to a Friend
Inventor 2013 does not provide midplane constraint. Workaround is to create Mate assy constraint between two planar faces. Then use half of constraint modifier(distance) as a parameter when creating new work plane defined by perpedicular distance form a plane.
Hope this helps.
Robert
- Highlight
- Email to a Friend
Correction, I should have used "Offset" rather than constrained, but the same parameter methodology will work.
Win7-64
