• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Midplanes in assemblies
    187 Views, 3 Replies
    11-18-2012 08:59 AM
    I'm a little confused.  After reading the documentation for IV 2013, I'm not sure if it's possible to create a midplane between parallel faces of two different parts or not.  I've tried using the workplane buttons in both the 3D Model and the Assembly tabs with no joy.
    Can someone please clarify?
    Thank you.
    Product Design Suite 2013 Ultimate
    Windows 7 64-bit
    Intel Core 2 Quad Q9300 2.5GHz
    8 GB RAM
    Nvidia GeForce 8800 GT
    Please use plain text.
    blair
    Re: Midplanes in assemblies
    11-18-2012 03:39 PM in reply to: chipwitch2
    You would need to use a parameter
    If the one plane is constrained to another work plane, you should be able to use the paramter ID / 2 as your mid distane.
    Work-Plane 2 is contrained from Work-Plane 1 by contraint "d26". You should then be able to us "d26/2" for your distance when you create your mid Work-Plane
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Employee
    t_stramr
    11-21-2012 05:12 AM in reply to: chipwitch2
    Inventor 2013 does not provide midplane constraint. Workaround is to create Mate assy constraint between two planar faces. Then use half of constraint modifier(distance) as a parameter when creating new work plane defined by perpedicular distance form a plane.
    Hope this helps.
    Robert
    blair
    11-21-2012 08:37 AM in reply to: t_stramr
    Correction, I should  have used "Offset" rather than constrained, but the same parameter methodology will work.
    Win7-64
