• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Microsoft Security Essentials and Inventor
    368 Views, 6 Replies
    07-01-2011 02:30 AM
    Recently i updated all workstations to Microsoft Security Essentials (MSE) anti virus. Now we notice some big performance issues when loading and saving to the Vault store.
    The MSE is in default configuration, including real time protection.
    Can this be a reason for the performance issue ?
    And what will be the best configuration (if any)  of MSE to work with Inventor ?
    Please use plain text.
    Distinguished Mentor
    ampster
    Re: Microsoft Security Essentials and Inventor
    07-01-2011 05:18 AM in reply to: coemter
    I use WSE and have no issues.  There was nothing that needed configuring in WSE in order to function with Inventor.
    If you had McAfee or Norton, you may have left over stuff in the registry and such.  I know Norton provides tools to completely uninstall their software on their website, I don't know if McAfee odes however.
    edit, however I do not use Vault so maybe there is something there, I can't imagine WSE would be scanning native Inventor files...
    07-01-2011 05:19 AM in reply to: coemter
    real time protection is scanning the files.. Typically with most virus programs you can add file extensions to ignore.. (I always put .iam, .ipt, .idw,etc.. into the ignore list or you can put a folder to ignore.
    Simply turning off real time protection to see if it gets faster again. (then add the ignore list and turn it back on)
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    karthur1
    07-01-2011 05:20 AM in reply to: coemter
    I use MSE too on about 10 workstations.  No issues here.
    What version of Vault are you using?
    Active Contributor
    07-05-2011 03:46 AM in reply to: coemter
    Thank you for your input.
    I was observing how disable real time protection change the performance. Without real time protection enabled performance is as before installing MSE.
    [ Inventor + Vault 2011 ]
    Distinguished Contributor
    07-06-2011 04:48 AM in reply to: coemter
    You can configure MSE to only scan new incoming files, and also exclude entire folders or file types. See the settings tab.
    karthur1
    07-06-2011 06:01 AM in reply to: hans.martin.haga
    I could be wrong, but I think that "exclude files,file types and process" from the system scan.  This helps speed up the system scan, but doesnt do anything to reduce the resources that MSE uses.
    With the Real-Time protection turned on, you can choose to monitor all files, only incoming files or only outgoing files.  I dont see any way to exclude only certian process from the real-time protection.
