• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    jyothissurendran
    Merge I beam by Frame Generator
    197 Views, 2 Replies
    11-19-2012 09:57 PM
    I have three i beams, two of them are perpendicilar and one is diagonal to others. I am trying to merge the end of diagonal beam with the other two beams. I tried the options "Trim Extend & Notch" for merging this, but it does'nt work properly. i am not getting a perfet result. My intension is to merge the web to web and flanfe to flange.
    Kindly advise if somebody knows any option. Please find the attached image more clear explanation.
    Jyothis Surendran
    Inventor Professional Suite 2010
    Windows 7
    Please use plain text.
    Re: Merge I beam by Frame Generator
    11-20-2012 03:55 AM in reply to: jyothissurendran
    Edit the beam to be cut in the context of the assembly.
    Copy Object the cutting surfaces from surrounding parts as needed.
    Sculpt or Split away the excess material.
    Valued Contributor
    jyothissurendran
    11-26-2012 02:27 AM in reply to: JDMather
    Dear JD,
    I got it merged by "notch and Trim/Extend".  Thanks for  your reply and time .
    Jyothis Surendran
    Windows 7
