Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Material Color Why is a part with color still shiny Shaded with edges display
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I apply a material to a part. When I select the visual style Shaded with edges I expect the view in pic 01. And when I select the visual style realistic I expect the view in pic 02. But when I do this in AI2013 it shows a shiny surface all the time.
Why not make it possible to add an extra asset to a material (see pic 03). 1 asset to set the shaded with edges display and another asset to set the realistic display. And also make it possible to show these displays on drawing and exports.
Tested on AI2013 with Update 2 installed.
Henk de B
Re: Material Color Why is a part with color still shiny Shaded with edges displa
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Henk,
In fact, the visual style for appearance display for the same asset, if you want to add different appearance display in different visual style, it could be hard. but there is an workaround follow the steps below:
1. Create a new view in "Represtation -> View" , for example, named "View 1".
2. Assign different appearance asset for the components you want to display in Realistic visual style.
3. Please change the visual style by switch Views and change the visual style manually, such as "Shaded with edges" in "Master view" and "Realistic" in "View 1" .
Picture attached for your reference.
Shaded with edges in Master view:
Realistic in View 1:
Xun Zhang
Software QA Engineer
Inventor Quality Assurance Team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Nice workaround, but it would be much better when this was arranged inside the material.
We work a lot with stainless steel (most times polished) but only for a good picture for the customer I wanrt the polished surfaces. When I model/engineer, I want the shaded surfaces.
Now when I set the materials to be polished the shaded view shows me polished surfaces.
Henk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Henk,
I've submit to our system for tracking the issue, thanks again for your report.
Xun Zhang
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I checked this in AI2011 and there it is working like I expect.
2 appearances inside the material, 1 for the sahede view and another for the realistic viewing.
Henk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Henk,
You are right. in the version 2011 and 2012, the rendering mode in code level for shaded/realistic visual style are totally different, but in version 2013, the rendering mode in code level for shaded/realistic is the same, that the exactlly reason.
By the way, I've address the issue to our system for tracking, thanks for your great feedback.
Xun Zhang
