• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Engibineer
    Re: Making the standard Content Center work.
    02-21-2012 06:29 AM in reply to: Engibineer
    Actually, according to this post, since I have IIS installed, there shouldn't be an Autodesk EDM Server service listed...
    Please use plain text.
    Engibineer
    02-22-2012 12:32 PM in reply to: Engibineer
    Alright, I've managed to achieve some incremental progress. I've been toying with ISS and I can now browse to 'http://localhost/TestASP/TestASPNetStatic.txt', but I have to go through a login prompt first. Logging in as Admin gets me past this prompt and displays the contents of 'TestASPNetStatic.txt'. The Autodesk Diagnostic Tool still fails to access though. I presume this happens because the tool does not have administrator login crudentials.
    I can also navigate to 'http://localhost/AutodeskDM/Services/SecurityService.asmx', but I get the same prompt.
    How do I keep this prompt from appearing and getting in the way? There's got to be a setting in IIS somewhere, right?
    Engibineer
    02-27-2012 11:07 AM in reply to: Engibineer
    Finally got it to work. Here's the summary of what our IT people did:
    * Read article "http://autodesk.lithium.com/t5/Autodesk-Vault/Vault-Problem-Please-help/td-p/3100166"
    * The issue must have been caused by demoting the old SBS server to a member server
    * Followed information in the support article to try to troubleshoot the problem.
    * Changed IIS authentication settings and permissions - did not fix problem
    * Uninstalled IIS role
    * Re-installed IIS role
    * Repaired Autodesk Database Manager - still not working
    * Followed article again - still not working
    * Deleted local IIS user and restarted IIS - this re-created the local IIS user
    * Followed support article again using the newly created IIS user - success
