• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Making a rectangular spring
    617 Views, 3 Replies
    05-02-2012 12:44 PM
    I have to make a spring for an engineering class I have yet me nor the teacher know how to make a rectangular spring. So please help me try to make it!
    Please use plain text.
    Re: Making a rectangular spring
    05-02-2012 01:05 PM in reply to: caleb.leftwich93
    3d intersection between helix surface and extuded surface
    then sweep
    attach your attempt here for further instruction.
    I recommend that your teacher go through ALL of the tutorials/papers in my signature and especially the Knot tutorial.
    Curtis_Waguespack
    05-02-2012 01:08 PM in reply to: caleb.leftwich93
    Hi caleb.leftwich93,
    Here's an example file that you can look at to see how it's done.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    05-02-2012 01:27 PM in reply to: caleb.leftwich93
    Here is another example with subtle differences - the key difference is the swept circle is on a plane perpendicular to the start point of the path to ensure the wire cross section is round.
    The example isn't perfect using this helxi intersection method - but should be close enough.
    If you need closer to perfect - post back and someone will suggest a slightly different intersection for the path.
