• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Making a Solid Blade Hollow
    160 Views, 1 Replies
    11-16-2012 05:44 AM
    Hello Sir
    I have turbine rotor blade designed as per the aerodynamic considerations. The profile i obtained from the company is completely solid, I would like to make it hollow with  a wall  thickess of 5 mm. I tried if with the Shell feature of Inventor, and Since the profile of the blade is in different planes twisted in different angles, the Shell is not working very well. I have tried it with loft with different cross sections, but i am not getting a completely accurate profile. Is there any tool which automatically recognises the outside profile and will make the Inside hollow also in Inventor? I will really appreciate if some one can give a solution from your valuable experiences..
    Thanks in advance
    Regards
    Sudheesh
    Please use plain text.
    Valued Mentor
    japike
    Re: Making a Solid Blade Hollow
    11-16-2012 06:09 AM in reply to: sudhi4cric
    You could start a new part and use the "Derived Component" tool to add the surfaces from the solid part into your new part. Then use the "Thicken/Offset" tool to add thickness to the surfaces.
    Peace,
    Jeff
    Inventor 2013
