Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Making Cable Look like its Growing
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello ,
Im working on this video where I have an assembly that is basically a drum wire wrap, and the cable wrapped around it appears to be growing as if the wire was actually stretching and moving from one end to the other and wrapping around another drum. The guy working before me labeled it "travel driver" and I really don't understand what's going on to make the cable travel and appear like its growing or stretching to reach the other side of the part. I can't show you a video because his inventor animation does not work anymore it errors with "failure to update model"
If anyone has any information on what "travel driver" might mean and how to make something look like its growing or stretching and traveling distance, your help would be greatly appreciated. Thank you in advance!
Re: Making Cable Look like its Growing
- Highlight
- Email to a Friend
My guess is Drive Constraint or a Animate Parameter was intended.
Can you attach the assembly here?
- Highlight
- Email to a Friend
can you upload the files?
XP 32-Bit SP3
- Highlight
- Email to a Friend
Im attaching a render I just made, I think I have a small understanding as to whats going on. Its seems there are two plates on either side of the small cable piece and the cable piece is made adaptive, both ends of the cable are mated to a plate. Then the "travel driver" is just a mate between the two plates and he animated the the distance between the two plates to become larger, and because the cable is adaptive , it looks likes its growing because its mated to the plate and the plate is moving so the adaptive piece grows to hold the mate?
Im sorry for the wording I think thats what he's done and I rendered what I think is what he did. I still dont know if im doing this right because I only found this assembly and animated the distance between the plates I didnt make the assembly file.
On a side note, I used the techsmith codec and you Im pretty sure you will need it to watch my render, so heres a link for it
http://www.techsmith.com/codecs.asp
Thank you for any help and your time in the matter.
