• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Macro/Keyboard Command For Exporting .idw To .dxf
    248 Views, 6 Replies
    10-26-2012 06:40 AM
    Hello everyone,
    I have keyboard commands set up for exporting my .idw drawings to .pdf format (PD for me.) I would also like to set this up for exporting my drawing to .dxf format. I think this can be done with a macro that can be activated by a keyboard command, but I could be wrong. I don't want to do this with an iLogic. Does anyone else have this written all ready? I have absolutely no experience with script writing and would appreciate any help! Or if anyone has a better suggestion, that would be great as well!
    ~Gary
    Please use plain text.
    *Expert Elite*
    karthur1
    Re: Macro/Keyboard Command For Exporting .idw To .dxf
    10-26-2012 06:54 AM in reply to: garmoor
    You can snip it out of this. (u will have to extract from zip first).
    *Expert Elite*
    Curtis_Waguespack
    10-26-2012 07:16 AM in reply to: garmoor
    Hi garmoor,
    Iin addtion to karthur1's reply, be aware that there is a customization forum where you can search and post programming related question such as this.
    http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    10-26-2012 07:19 AM in reply to: karthur1
    I have loaded the ivb file and assigned it a key prompt (DX.) However, when I enter this, nothing appears to happen. Am I doing something wrong?
    *Expert Elite*
    karthur1
    10-26-2012 07:33 AM in reply to: garmoor
    Just wondering... are u doing this so you can export the flat pattern?
    Member
    10-26-2012 07:36 AM in reply to: karthur1
    No, I need to export the entire drawing (side views and all) into DXF. The line that it's asking me to debug is:
        b = dxfAddIn.HasSaveCopyAsOptions(file, context, map)
    *Expert Elite*
    karthur1
    10-26-2012 08:00 AM in reply to: garmoor
    Not exactly sure why you are getting that error. Hopefully someone else can take a look.
