Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: MOLD Design - cutting surface
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI
It is my first time to use silhouette curve, i must admit is an amassing tool, together with the MOLD software
I just used the silhouette curve command, and automatic selection a gess
I will tray to go truth you steps and tray to get the same model as you did.
Regards
Henrik Lørup
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hello, JDMather,
Please refer to the following links about using silhouette curve to create hole patch and runoff.
http://wikihelp.autodesk.com/Inventor/enu/2012/Hel
BTW, for hlo's specific part, I wasn't used the whole silhouette curves of this part to create runoffs because of two small twisty regions and I connected the adjacent runoffs directly.
Mingwei Gao
Software QA Engineer
Inventor Quality Assurance Team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI
Tangs for helping, i will study all regarding this MOLD design
Regards
Henrik
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I need to re-open this tread.
I did some study in Mold software and Core/Cavity, but this item I do have some problems with.
I need to know if there is a way, to make the runoff easy by using the silhouette curve. I know form reply, from the command I using to generate core and Cavity, some problems are exciting.
The item “Item1.ipt” I used the “silhouette curve” and tried to make runoff surface but it is not working.
The item “Mold Design Emne 1_Mold Item-silhouette curve_MP.ipt” I did some modifications and got finely a runoff surface, but still error.
Is this item just to messy designed og what, to making the runoff surface the will do the job.
Regards
Henrik
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you pack and go your all Mold design files and send them to me(Mingwei.Gao@autodesk.com)? From your provided two parts, I cannot see any runoffs in them and missed some reference models.
Mingwei Gao
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI
I did the pack and go, hope something will come out for it.
Regards
Henrik
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello Herik,
I had a look at your Mold design datasets and I have to say the silhouette curves of this part are very complicated and some regions are not suit for parting lines. The current result looks not realistic for Mold manufacture. This is also the reason of core and cavity split failure. Can you modify the silhouette curve in some regions to let the parting lines smooth and then create the related runoffs?
Mingwei Gao
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI
Thangs for having this second look at this part, I just need to be sure that I didn’t foresee
something. I will tried to do modification much mort to be able getting the right result
Regards
Henrik
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Henrik,
If you are interesting in my testing design result of your model, please give me a Mail address and I can send it to you. Because the file size of the all design files is about 5M and I cannot post it in here.
Mingwei Gao
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
