• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Lost visibility of components in assemblies
    218 Views, 5 Replies
    01-10-2013 02:58 AM
    Hi all, I've a serious problem. Opening large assemblies containing LODs some components missing. The assemblies are build with inventor 2010 and now is totally migrated in in 2013 SP1.1 Update1. If you open the subassemblies these are correctly on. I've tried to set visibility on, off, change rappresentation of view, positional and activare various LOD, including Principal LOD.
    If you position another istance of the subassemblies, one is on but the other isn't visible. In the drawing all is correctly rappresented
    See the attached .PDF
    This occours in Facroy and Product design suite. Graphics card and relative drivers are certificated. I can't attach a P&G because is a very larga file (250Mb).
    Please use plain text.
    Active Member
    Re: Lost visibility of components in assemblies
    01-12-2013 01:54 AM in reply to: cgusi
    Anyone have a little IDEA!
    This in a very big problem for me. I can repositioning another istance of a subassemblies and constrain it again but I can't do this for the second sub assembly. It can't be visible!
    So, I think that is a very big problem for the Autodesk's guru too.....
    Active Member
    01-26-2013 08:24 AM in reply to: cgusi
    Many thanks to Autodesk that open a ticket contact me directly and solve the problem.
    *Pro
    sbixler
    01-27-2013 04:59 PM in reply to: cgusi
    But you can't mark it as the solution unless the solution is provided!  Please let us know what the answer is.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Product Support
    Re : Lost visibility of components in assemblies
    01-29-2013 02:57 AM in reply to: cgusi
    The problem of the visibility was due to different things we observed like an incomplete migration of all components, some assemblies containing substitutes with broken links to their original assembly which had created an issue with a LOD. After removal of this "corrupted" LOD and different cleaning operations, the problem was solved and the “sub-assembly” was again visible .
    Nicolas.Bourquin
    Support Specialist
    Product Support
    *Pro
    sbixler
    01-29-2013 03:45 AM in reply to: Nicolas.Bourquin
    Thank you, Nicolas.
    Sam B
