Lost Projects
Lost Projects
Lost Projects
Can any body tell me how to cure this problem.I get the message that is shown in the attachment, but the projects are still there.
I cleaned up my computer and the i got this problem.
Inv 2010
Thanks for any help
Chris
ampster40
You'll find .ipj files in two locations for each project file, I suspect you deleted one of them and left the other one behind which is why you are seeing that msg.
 You'll either need to recreate the missing .ipj files or delete the other corresponding .ipj file to cure this.
blair
Check the Recycle bin, or use some Un-Delete/Recover software and you might be able to recover the files. Windows doesn't completely delete the file, it only deletes the first character of the file name (unless you use a "Wipe" software) to permanently delete the file.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
