Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Loosing references SIMPLE EXAMPLE-cr oss part references , adaptativi ty -
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have three parts 1, 2, 3,.
1 is grounded
2 refers to 1
3 refers to 1 and 2
I change 1 and references get lost.
INVENTOR 2011
WIN 7
32bit
Re: Loosing references SIMPLE EXAMPLE-cr oss part references , adaptativi ty -
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You already have an unresolved reference in your part 2. If I redefine it, then add some sketch lines between the two parts, extrude to make a rectangle, I now have three part geometries. Say I chamfer the outside edge in part 1, it updates in part 2 correctly. See picture.
If you change geometry that another part is dependent upon then it must not affect the rebuilding of the part. Things like sketch constraints that are now in conflict, or adding another face to a part so that your sketch has no clear attachment point, etc. All about what part of it you want to be flexible.
What exactly are you trying to create with adaptivity?
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I already have the unresolved reference because attached the result. Please check the video to see how it is created.
You can experiment using the file below.
When you change the width (not length and not extrusion) of part6 it appears.
please check the video:
http://grozny.spox.info/vid.avi
It is just a simple example, but it hapens many times. I have to refine references over and over again in my projects.
All help will be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is nothing in your video.
When I use your projected geometry it breaks. When I delete your projected references and project them my self it doesn't break, no matter what width I change it to.
Also why is part 6 adaptive..
What are you trying to create anyway, perhaps I can try that and see if it works?
Stew, AICP
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Part 6 is adaptive because its length depends on Part 5.
I am trying to construct something more complex. I posted it 2 days ago, with similar problem.
So the question remains:
Why sometimes the references brake and you have to renew them.
My reference breaks even if I just add another constraint between parts 5 and 6 without changing any shape.
It is all about the sequence of actions.
My reference brakes because I made it and then I constrained parts 5 and 6.
If I constrained parts 5 and 6 first and then made the reference it would last.
I can't understand it and it makes the design very frustrating.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please check that file. This is the same problem in my project. I have no idea how to cope with it.
I want to control the shape of the container with szkic.ipt, but everytime I change it, everything goes wrong.
It works only when I suppress Klapa Górna.ipt
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think the assembly file was missing from the zip.
Some things I would do first.
1. Fully constrain all sketches.
2. Make sure all parts are full constrained.
3. Ensure adaptivity (either feature or sketch) is being driven in the correct direction and only one direction at a time.
4. Look into master sketch / derived parts and multi-body master parts. Both of which can handle this sort of thing much better.
Adaptivity can work but it can be a bit temperamental, even if you set your model up correctly.
Stew, AICP
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, now am I sending it all.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The part 'Tyl' is missing..
Also why are you including your ends in the sheet metal part? They should be separate parts or you wont be able to flatten it later. Also are you going to be able to fold this part, it looks like it will have to be welded together from a couple of pieces.
Instead of creating all the faces I would have used a contour flange to create the whole shape in one go.
I will attach an example using a multibody part and a derived surface tomorrow, no time now sorry. I think it will work much better for what you are after.
Stew, AICP
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The part 'Tył' is there. Remember that it is written with 'ł'.
I did it that way to be able to manipulate the surfaces using one drawing. Otherwise (using fold function) I would have to change all the angles separately or use many variables.
Moreover the sides are not rectangular so it has to be done that way
It is unfoldable so it works pretty well until I add Klapa Górna.
The question is:
If all is correct, can I rely on "adaptivity" or just don't use that function at all?
This time and in many cases it fails without a reason.
Dominik
