Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Loft with multiple openings
- Highlight
- Email to a Friend
Hi
I was wondering if it is possible to make a surface loft go from 1 square section to 2 round sections.
So 1 ingoing section en 2 outgoing sections.
I've attached a simple drawing.
Many thanks in advance!
Nick
Re: Loft with multiple openings
- Highlight
- Email to a Friend
I think it may be possible to do two seperate lofts as surfaces, then once these surfaces exist, do a sculpt to create a solid.
Let me know if you need me to explain in more detail.
Edit: I have had a bit of an experiment with it but so far I can't seem to be able to get the sculpt to compute. I think the surfaces need to be merged together somehow first. I have tried using 'stich' but this didn't seem to solve the problem.
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2011
Windows 7 Enterprise, 64-bit
- Highlight
- Email to a Friend
Wayne Helley,
I suggest you make the 2 lofts in solid. Then delete the 3 faces and you will get a surface.
Something like that:
Windows 7 x64
Dell Precision T7400 Intel(R) Xeon(R) CPU X5472 @ 3.00GHz (4 CPU's), 8Gb RAM, NVIDIA Quadro FX 5600 1536MB GDDR3
- Highlight
- Email to a Friend
Hi Nick,
It’s not too difficult to loft square to 2 rounds, but the transition is not really pretty,
It would look nicer if the square edges had radii if allowable.
Just keep in mind the topology of the loft.
Keep loft edges to the same edge count, (i.e. not 1 edge to 3) etc...
Cheers
Mark
- Highlight
- Email to a Friend
Thanks for the quick answers.
I found a method which gives a satisfactory result.
First I made 2 lofts, next I deleted the faces in between the lofts and finally, I patched the 2 lofts together.
I have attached a screenshot of the result.
Thanks everyone for the replies!
- Highlight
- Email to a Friend
If you want this to be a true sheet metal transition which could be flattened, you would have to make two halves like the attached.
Inventor 2012 SP1
Vault Pro 2013
