• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Loft with multiple openings
    304 Views, 5 Replies
    01-24-2013 12:47 AM
    Hi
    I was wondering if it is possible to make a surface loft go from 1 square section to 2 round sections.
    So 1 ingoing section en 2 outgoing sections.
    I've attached a simple drawing.
    Many thanks in advance!
    Nick
    Please use plain text.
    Valued Contributor
    Re: Loft with multiple openings
    01-24-2013 02:10 AM in reply to: nick.jeuris.hotmail
    I think it may be possible to do two seperate lofts as surfaces, then once these surfaces exist, do a sculpt to create a solid.
    Let me know if you need me to explain in more detail.
    Edit: I have had a bit of an experiment with it but so far I can't seem to be able to get the sculpt to compute.  I think the surfaces need to be merged together somehow first. I have tried using 'stich' but this didn't seem to solve the problem.
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    Valued Contributor
    01-24-2013 02:46 AM in reply to: waynehelley
    Wayne Helley,
    I suggest you make the 2 lofts in solid. Then delete the 3 faces and you will get a surface.
    Something like that:
    AIP 2014
    Windows 7 x64
    Dell Precision T7400 Intel(R) Xeon(R) CPU X5472 @ 3.00GHz (4 CPU's), 8Gb RAM, NVIDIA Quadro FX 5600 1536MB GDDR3
    Valued Contributor
    Mark.Downes
    01-24-2013 03:49 AM in reply to: nick.jeuris.hotmail
    Hi Nick,
    It’s not too difficult to loft square to 2 rounds, but the transition is not really pretty,
    It would look nicer if the square edges had radii if allowable.
    Just keep in mind the topology of the loft.
    Keep loft edges to the same edge count, (i.e. not 1 edge to 3) etc...
    Cheers
    Mark
    Member
    01-24-2013 06:32 AM in reply to: nick.jeuris.hotmail
    Thanks for the quick answers.
    I found a method which gives a satisfactory result.
    First I made 2 lofts, next I deleted the faces in between the lofts and finally, I patched the 2 lofts together.
    I have attached a screenshot of the result.
    Thanks everyone for the replies!
    Valued Mentor
    mpatchus
    01-24-2013 07:35 AM in reply to: nick.jeuris.hotmail
    If you want this to be a true sheet metal transition which could be flattened, you would have to make two halves like the attached.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
