• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    razortje777
    Re: Loft between 3D sketch and normal sketch
    12-24-2011 01:24 AM in reply to: wolterh6
    Hello JDMather
    I have 'researched' your loft.ipt file and try to copy it step by step in my own CAD file from the cylinder.
    But a few things I don't understand:
    Where can I find the option 'Edges' in the menus?
    What are the functions of those 3D lines you have drawn?:
    When I thicken the wall-surface for instance with 10mm to the outside (to get a cylinder wall), how can I let these 'holes' filed up so that they are smooth rounded around the inlet ports?:
    Thank you in advance!!
    Please use plain text.
    12-24-2011 05:05 AM in reply to: razortje777
    I did not know whether the information you provided before was to the inside bore of the cylinder or the the outside.
    I was simply providing a quick example.  (For example, I didn't bother to get those sides between the ports created by parallel lines with parallel sides).
    To model the actual geometry I would have to know more information and spend a day or two on experimentation.
    Edges are edges of existing geometry by selecting a face or a surface.
    razortje777
    12-28-2011 02:08 AM in reply to: JDMather
    Thank you for your answer.
    But I don't understand it quit well. For question 2 and 3 I'm still looking for an answer because I don't know yet how I could fill those 'holes' up arround the inletports.
    And I have searched again for more then an hour but I can't find the option 'edges'. Could you please let me know where to find it?
    Thank you.
    razortje777
    01-02-2012 12:04 PM in reply to: razortje777
    I am sorry that I reply another time, but after days of searching on the internet, help topics... I still can't find that option 'edges'
    And also the other problems, I can not solve.
    I hope that someone could help me find that option, and could help me solve those other problems.
    Thanks in advance! I really appreciate it, because it get's me a bit frustrated this problem after 2 months :smileysad:
    01-02-2012 12:27 PM in reply to: razortje777
    When you select a face or a surface Inventor selects the Edges.  Edge selection gives more functionality than sketch selection.
    You should put your part aside for a bit and go through the tutorials in my signature.
    Especially this one
    http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
    and this one
    http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
    razortje777
    01-03-2012 09:48 AM in reply to: JDMather
    Thank you, now I finally found the 'edge function' and therefore I was able to draw the inlet ports.
    For now, the cylinder is finished exept for one last anoying thing...
    For some reason I can't 'Thicken' the cylinder wall, or 'extrude' it between the two sketches...
    Could you please help me with this last step?
    Then this model is finished, and I will start with some Inventor courses to learn more of it (basics for instance).
    Here is the file:
    http://wtrns.fr/tioDo-2-CpBxt6
    Hope you really could help me with this last step.
    Thanks in advance!
    Gr,
    Lennart
