• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Loft Problem
    178 Views, 4 Replies
    10-30-2012 06:55 AM
    Is it possible to loft a shape which includes a hole or a section missing?
    I am trying to loft the following shape but it doesn't seem to work with the missing section in the middle. Currently the 2 sketches are the same but in the actual design they aren't. i wanted to test if it would work with the same sketches but it doesn't.
    If it is not possible what would be the easiest solution?
    Please use plain text.
    Distinguished Mentor
    Re: Loft Problem
    10-30-2012 07:05 AM in reply to: kevin.vayro
    Why not just extrude it?
    John Retzlaff
    New Member
    Re: Loft Problem
    10-30-2012 07:10 AM in reply to: john.retzlaff
    I want a curved profile to the edge, I just haven't included it. I thought loft would be the easiest way but maybe it isn't.
    I'm trying to achieve a similar profile to what is in this image.
    *Expert Elite*
    Re: Loft Problem
    10-30-2012 11:50 AM in reply to: kevin.vayro
    Loft in two steps.
    Step one for the outer shape.
    Step 2 to cut the holes.
    Attach your file here if you can't figure it out.
    *Expert Elite*
    sam_m
    Re: Loft Problem
    10-31-2012 01:54 AM in reply to: JDMather
    to elaborate on JD's post - Inventor cannot loft a profile with a void in the middle to create a lofted tube.  But I can loft the exterior face and then loft the interior face (with a cut) to create what is desired in 2 steps.
    Assuming you are using rails with your loft (instead of centre-line), to give you a curve/bulge to the shape along the length of the loft, then you're probably going to want a set of rails for both the inner and outer profile to get them to match.
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
