• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    Loft Advice
    354 Views, 4 Replies
    01-20-2013 08:06 AM
    Im struggling coming up with a loft or sweep to get the design effect I need. Please see on the pic how the profile terminates to a point. Any help or advice would be appreciated
    Please use plain text.
    Active Contributor
    Re: Loft Advice
    01-21-2013 06:09 AM in reply to: SPGMATT
    I am a beginner myself, and I am sure someone will come along and give you proper advice, but I'll give it a bash later on.
    I'll try a 3d sketch intersect to create the lifted bit, and maybe use split to try to loft bit by bit around that tight corner.
    Cheers
    *Expert Elite*
    blair
    Re: Loft Advice
    01-21-2013 08:33 AM in reply to: SPGMATT
    Create your round end first, most likely a Revolve to form the end Button. Then create your Sweep from this. You should be able to copy the outer edge of the Button onto the sketch for the profile of the Sweep
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Valued Mentor
    mpatchus
    Re: Loft Advice
    01-21-2013 11:51 AM in reply to: SPGMATT
    Just a real quick 5 minute attempt, but you can get some ideas from it.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    New Member
    Re: Loft Advice
    01-23-2013 02:49 PM in reply to: mpatchus
    Thanks for your help Mike, I got it
    Steve
