• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    List of Shortcut Keys...
    4021 Views, 13 Replies
    08-26-2011 06:08 AM
    Is there a printable list of all configured (default and custom) shortcut keys?
    Please use plain text.
    *Expert Elite*
    Re: List of Shortcut Keys...
    08-26-2011 06:43 AM in reply to: KF090
    Yes  (see attached)
    I think I discuss how I add or change some of them in this paper  http://home.pct.edu/~jmather/skillsusa%20university.pdf
    Distinguished Contributor
    Short Cut Key Lists Attached
    08-29-2011 02:46 AM in reply to: JDMather
    "In the Customize dialog box, Keyboard tab, use Copy to Clipboard to copy a list of command names and their assigned aliases and shortcuts to the clipboard. You can paste this data into an Excel spreadsheet or any word processor."  WikiHelp - Custom shortcut keys
    I've also attached Single and Multiple key lists in a few different formats.
    I like JD's short cut suggestions (see the link in his post) for sketch constraints using punctuation keys and symbols.  I tried assigning different Display Modes (Shaded, Shaded with edges, Shaded with Hidden edges) to the keyboard numbers.  In 2011 it works out just about right as there are about 9 display modes.  This is very useful; it gives me an easy way to see things differently.
    Geoffrey Wheeler
    IV Pro 2011 64bit SP2; Win7 Ultimate SP1
    ASUS MB Intel i5-3450 @ 3.10 GHz, 8GB RAM
    ATI AMD Radeon HD 6600 Series, 1GB RAM
    Valued Contributor
    Re: Short Cut Key Lists Attached
    08-29-2011 06:38 AM in reply to: cvbt-thailand
    Thanks guys. :smileyhappy:
    10-17-2011 12:54 PM in reply to: KF090
    Better yet, here's a macro to produce the list on demand (in Excel).
    Active Contributor
    Lawson2011
    01-24-2012 09:12 PM in reply to: cadfish1
    try this
    01-25-2012 06:35 AM in reply to: Lawson2011
    The file you have attached is for AutoCAD LT and can't be used by Inventor (i.e. wrong discussion group).
    New Member
    05-05-2012 01:25 AM in reply to: KF090
    Could you please explain how to use the file in the zip file you have attached?
    05-07-2012 09:32 AM in reply to: KF090
    1. With Inventor as Windows active application, press the F11 key which brings up the VBA Editor then go to the File menu > Load Project... > select ShorCuts.ivb
    2. Go to Inventor > Tools > Macros > select ShortCuts_ExportToExcel > Run button
    Valued Contributor
    10-05-2012 12:06 PM in reply to: cadfish1
    cadfish -
    I can't seem to get this ivb file imported into my VBA editor.  I choose load project, browse to the file, pick it and choose open.  Then nothing happens.  When I look at my list of macro's there's no additional macros there.
    Am I missing something?  Using IV2012.
    Thx
    Inventor 2013 64-bit SP1.1, single user
    Win 7 Pro 64-bit SP1
