Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Linking Drawing Dimensions to a Table
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is it possible to link the dimensions in my .idw to the table in the upper left corner? I want the information in the table to reflect what is in the drawing.
I'm using Inventor 2012
Thanks!
Steve
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Re: Linking Drawing Dimensions to a Table
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Steve
I think you would have to convert your model into iPart. Then the dimensions will be available to populate the table.
Igor.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure I understand. Why would converting it to an i-part be any different? Don't the dimension properties still reside in the file?
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sadly don't know a way to insert model parameters into a table but you can do it with a text annotation:
"Unit Height: Model Parameter d0
Unit Width: Model Parameter d1" etc
Using the bottom row of drop-downs in the text editor dialog box...
Arguably not as neat as a table, but could draw a text box around it all...
Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
Lithium - helping nntp users with mania, depression and headaches
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sam:
Could you send me a screen shot of where to enter this? Thanks.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi SteveFrey,
It looks to me as if this is an assembly. Are the dimensions you want in the table available as assembly parameters?
If so you could check the Export box in the parameters dialog box and then they will be available as Custom iProperties. Then you could use a Parts list as the table and pull that information in. I'd consider making all of the information in that table custom iProperties also, just so that becomes container for all of the info.
Now if those dimensions you want to pull into the assembly do not exist in the assembly, you might need to go to the Parameters dialog box and use the Link button, and then Link to the part files and import the parameters.
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay. I will fool around with it and see how it goes. Thanks again.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Steve
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
