• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Lines do not connect for extrusion
    445 Views, 3 Replies
    06-09-2012 06:36 PM
    All of a sudden, my line tool in sketch mode does not connect segment to segment and each individual line can be dragged wherever. This also means I cannot extrude any shapes I make because inventor does not realize the series of line segments create a closed shape. This happens across all part files, old and new.
    Any ideas? Thanks!
    Please use plain text.
    Active Member
    Re: Lines do not connect for extrusion
    06-09-2012 10:55 PM in reply to: connorzwick
    Additional info: when I try to close a shape, the green dot doesn't come up; it is still the yellow and if I try to close by clicking on another line, it still gives me another segment to place after. I tried reseting settings by clicking on Default Inventor settings in options to no avail...
    trumpy81
    06-09-2012 11:02 PM in reply to: connorzwick
    Are you using Inventor 2013?
    Click the drop down triangle beside constrain on the ribbon bar, and select Constraint Options. Make sure everything is ticked.
    Hopefully that will sort out the problem for you.
    Regards
    Andy M
    Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
    Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
    1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
    Active Member
    06-09-2012 11:23 PM in reply to: trumpy81
    thanks! that worked!
