• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Limits of an Inventor part or assembly?
    918 Views, 26 Replies
    03-03-2010 05:25 AM
    Hello, all -
    Visiting from the AutoCAD side of things, I wondered if there was a limit to the size of an Inventor part or to the dimensional extents of an Inventor file?
    -Bill
    Please use plain text.
    *Dennis Jeffrey
    Re: Limits of an Inventor part or assembly?
    03-03-2010 07:35 AM in reply to: bill.gilliss
    AutoCAD is the only unitless CAD system in popular use. Because it is
    unitless, there is no maximum distance.
    3D Modelers are unit based, and mathematically there is a limit on
    individual part sizes. The Inventor 2010 part I have attached is a 5
    foot diameter cylinder with a length of 6400 feet. It fails to extrude
    somewhere between 6400 and 6500 foot in length. This is a single part file.
    Assembly files in Inventor do not have a distance limitation since
    individual parts and subassemblies are merely linked, not calculated
    within the assembly file.
    Do you have a need to create single parts over 6400 feet? BTW, the Mass
    of this part in mild steel is: 61661137.021 lbmass (Relative Error =
    0.000000%).
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Subscribe to the free "The Creative Inventor Magazine now available at:
    http://teknigroup.com/CI-Subscribe-Login.asp
    03-03-2010 07:42 AM in reply to: bill.gilliss
    >Because it is unitless, there is no maximum distance.
    Actually the size limit or extreme distance from origin is well known problem in AutoCAD.
    Here is info from Rhino - I have seen similar information for virtually all CAD programs I have used.
    Rhino, like most CAD products, represents position in double-precision floating-point numbers. That means the x, y, or z coordinate of any point can have a value ranging from as large as ±10E308 to as small as ±10E-308. Most CAD software, including Rhino, uses double-precision floating-point arithmetic.
    Because of the limitation of current computer technology, we expect calculations to be accurate to 15 digits of precision in a range from ±10E20 to ±10E-20. This limitation is found in all modern CAD products.
    Older CAD products often have additional limitations because they were developed originally to run on computers with less precision. For example, many CAD modelers are designed for performing calculations on geometry that is restricted to be in a box of size 1000x1000x1000 meters centered at the origin. (Geek alert: Another of the popular off-the-shelf modeling kernels requires parameterizations that are within a factor of 10 of being arc-length parameterizations.) Rhino has none of the limitations found in these older products.
    Jeff Howard covered this topic here a while back, but now I can't find the thread.
    Active Contributor
    03-03-2010 08:58 AM in reply to: bill.gilliss
    This is what I was wondering about -- just curious. No 1.2 mile long single parts in my immediate future! Thanks to all.
    *Igor Mironenko
    03-03-2010 10:21 PM in reply to: bill.gilliss
    Here is an AutoCAD file which shows our Solar system in 1:1 scale. If you
    zoom close onto the Moon you will see the lunar module over there plus a
    memorial plate left by the astronauts.
    The file was created years ago to demonstrate AutoCAD zooming capabilities.
    BTW, using AutCAD since R12 it is the first time I hear that there is a
    "well known problem in AutoCAD" with parts size or extreme distances.
    Igor.
    Web: www.meqc.com.au
    www.boatworks.meqc.com.au
    ----- Original Message -----
    Newsgroups: autodesk.inventor
    Sent: Thursday, March 04, 2010 12:04 AM
    Subject: Re: Limits of an Inventor part or assembly?
    problem in AutoCAD.
    *Dennis Jeffrey
    03-04-2010 05:48 AM in reply to: bill.gilliss
    I agree.
    Actually, AutoCAD is the only CAD system that can handle angstroms to
    parsecs in measurement.
    03-04-2010 06:10 AM in reply to: bill.gilliss
    >the first time I hear that there is a "well known problem in AutoCAD" with parts size or extreme distances.
    Guess I'll do some research for you and post links to numerous sources and proofs when I get a chance - check back for the urls in a couple of days.
    Employee
    03-04-2010 10:42 AM in reply to: bill.gilliss
    The maximum size of an Inventor part model (only part) is bounded by a cube of 10000cm X10000cm X 10000cm. When a solid body exceeds the boundary, the modeling commands will behave unpredictably.
    For assembly, there is no internal size limit on how big an assembly can be. However, it is restricted by hardware (memory, CPU) and OS (maximum floating number allowed).
    Thanks!
    johnson.shiue@autodesk.com
    Principal SQA Engineer, Inventor
    Manufacturing Group
    03-04-2010 04:26 PM in reply to: bill.gilliss
    I believe there are a few known tricks to get around the problem. Scaling, inserting....
    Here is an interesting read. I'll post more examples as I have time to find.
    http://autodesk.blogs.com/between_the_lines/2004/01/more_on_autocad.html
    >" Of course by simply moving this object temporarily closer to the origin of 0,0 the offset works perfectly because less digits are used in this calculation and no rounding issues. "
    The other examples I will reveal deal with 3D solids editing problems - can't add fillet or can't shell, that sort of thing.
    *Igor Mironenko
    03-04-2010 04:37 PM in reply to: bill.gilliss
    It is funny that you jump into such topic head on but when I asked a real
    Inventor question you were nowhere near to see.
    Igor.
    wrote in message news:6348571@discussion.autodesk.com...
