Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Lighting styles for shaded views in an .idw
- Highlight
- Email to a Friend
I've been working with a model where some of it is in a dark shadow when I make a shaded view on the drawing. I've created a custom lighting style in the style manager, but I haven't found any way to succesfully assign that lighting style to the model in a way that will light the shaded views in my drawing. I'm using Inventor Pro 2011. Any thoughts?
Re: Lighting styles for shaded views in an .idw
- Highlight
- Email to a Friend
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
- Highlight
- Email to a Friend
This particular registry edit doesn't work for what I'm trying to do. Here's a simplifed example. I created a white cube, and some of the faces are grey due to the lighting when I make a shaded view in the drawing. So I have gone inot the style manager and modified the lighting to remove the shadows ( in this examp[le I changed the light color to red so its more pronounced). I went in created the registry key, shut down Inventor,a nd even tried a restart, and both opened the existing drawing and tried creating a new drawing, as as you can see the change in the lighting color doesn't show up in the shaded drawing view.
- Highlight
- Email to a Friend
OK.. Now I seem to remember a long time ago that I had this problem too .. I believe I had to edit the lighting.xml file because the lighting in an IDW is forced by the "Default" lighting style and is not tied to the part or assembly lighting styles.
I'll see if I can remember where I did that. or what I did..
Sort of discussed here
http://forums.autodesk.com/t5/Autodesk-Inventor/Li
Open the xml file (make a copy first) then edit that "#1-Default" lighting style and that should fix it..
Windows 7 64 bit
- Highlight
- Email to a Friend
Thank you, at least that points in the right direction. But I'm not much a a coder, so any further info that you could provide on modifying the .xml file would be very helpful.
Thanks again ![]()
