Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Level of Detail problem
- Highlight
- Email to a Friend
Yep, I believe you are correct. This morning, (while holding my breath in fear...) I tried to reproduce the problem. I opened the drawing and then the model, and the problem did not occur, then I shut down, fired up again and opened the model THEN the drawing, and voila... "Cannot save... LoD being edited..."... It loks like the model, having the different LoDs buried in its subassemblied is getting confused by the drawing being open.
- Highlight
- Email to a Friend
I'd like to point out my first objection to this issue... the error message...
It states that an LOD (current or different, who cares?) is beign EDITED. NO, IT IS NOT!!!! An LOD cannot be edited from within the drawing environment, right?
Thanks for posting your observations about "which came first". The fact that you get a different result when one comes before another indicates, to me, that Inventor has a problem and it's not your fault. While I had never made the connection of "which came first", I realize that it is very difficult to reproduce this issue and therefore impossible for the support personnel to solve it.
It was previously suggested that I delete & re-create my Windows User Profile to solve this issue. It worked, but within a few weeks the issue has resurfaced. Said deletion and recreation of Windows User Profile is time consuming and MAY result in data loss. I wonder why this method seemed to have good results. Is there some kind of conflict with Windows (I'm using 7) and Inventor (I'm using 2012).
John
- Highlight
- Email to a Friend
Just tried to open the drawing first... then a workflow with the model first... can't duplicate my issue. It doesn't seem to be related to which file is opened first (for me).
A few days ago, I had some data loss. Inventor would NOT save the changes I made despite going back-and-forth several times between the model & drawing doing "saves". I saved, saved, saved, created a .dwfx of the drawing, re-opened the drawing & model only to see that changes were NOT saved BUT the dwfx DOES show the changes (made but not saved somehow).
I don't think it should even be possible to get the .dwfx "out of sync" like that... should that be possible?
- Highlight
- Email to a Friend
I haven't gone through and read the other messages, but I recently had a similar issue which I fixed;
You need to go through your assembly parts and find out which one of them has an open LoD on - perhaps it is one which you already have open or someone else does?
Once you find it and save the amendments, your assembly will be fine.
Autodesk Inventor Professional 2012
Windows 7 Professional, 64-bit (Service Pack 1)
Intel(R) Core(TM i7-2600 CPU, Quadro 2000 graphics card, 8G RAM
- Highlight
- Email to a Friend
Thanks Phil. I'm glad to see you were able to make it past this issue! You are appreciated.
Let's look back @ the original message... it says "cannot save" NOT "you must save". There's the "normal" message... somethig is different between the two... you must save or abandon changes...
Then there's this "problem" message... you cannot save because...
Here's the problem Inventor has caused (after the cannot save message)...
save the model (it doesn't say it didn't work)
save the drawing (it doesn't say it didn't work)
save model, save drawing (surely the 2nd time would make sure it saved, right?)
Export a dwf from the drawing. Close drawing & model.
Review dwf... it looks like you want... the LOD change appears BUT open the model & drawing... oh noes, the changes did NOT save (how is this possible?).
"Cannot save" is not acceptable. You're telling me that I've wasted my effort simply because both an assembly and a drawing that refers to said assembly are open at the same time. Baloney! It works that way most of the time. Can anyone take the time to actually identify the cause to these two, different results (cannot save vs. must save)?
Thanks In Advance,
John
- Highlight
- Email to a Friend
Thanks, though like I said in my previous post, I had a similar issue in which I had an assembly open with LODs at the top level. However, at the same time I also had several parts (which I was working on in parallel) open, one of which I later realised had an LOD that hadn't been saved.
It was that part which was holding up the assembly, giving me a very similar message in that any changes would be lost at assembly simply because deep down there was an unsaved part with an LOD activated. Once I sorted the offending part, everything was fine and the assembly level "cannot save" message disappeared.
I can't help thinking that perhaps a colleague of the OP is working in situ and has a part (not the assembly) open with an LOD activated?
The model and drawing conflict has never happened to me though, but like I said, the situation above garnered a similar response.
- Highlight
- Email to a Friend
I would suggest, that in order to prevent future problems that you work on things individually as opposed to running two tethered object (drawing / assembly) in parallel. If that isn’t possible, then these problems will most likely persist until they make absolutely sure that things are not being update / re-referenced / redrawn any time that you open a referenced document that has been linked to a drawing (and is trying to update in real time, but can’t due to the fact that the editing focus has been now taken away from it!).
It’s not the best solution in the world, but it’s the easiest to live with and a lot better than having to redo work or having Inventor crash.
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
- Highlight
- Email to a Friend
Phil,
Thanks again.
A couple of points...
1.) I work alone, no one could have my files in use.
2.) Parts don't have LOD's... only Assemblies (in 2012 at least, but I'm hopeful)
Mega,
Thanks. I accept your suggestion as a "work around". If I couldn't have a drawing open while I edit a (any?) LOD in the Model, I probably wouldn't have purchased Inventor. This can't be how it is supposed to work... a "must save" message is understandable but a "cannot save" or Inventors failure to save (without reporting such failure) is not.
When I'm at work, I prefer to work rather than "work around". When my car has a flat, I get out the jack... not the "jack around"! ![]()
I'm going to state for the record that I think something is not quite right about the situation I am encountering. If I had just started using the software and immediately had this "issue", I'd simply accept that the drawing and model cannot be open at the same time. BUT, I'm not not a new user and I'm not using it in a different way than I have for months and months.
Thanks again to everyone!
- Highlight
- Email to a Friend
D'oh of course I knew that you can't get levels of detail in part mode, I was just testing you ![]()
- Highlight
- Email to a Friend
Thanks for making it FUN!!!![]()
I get too serious about work and can use a good chuckle every now and then!
