Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Level of Detail in 2010
- Highlight
- Email to a Friend
- Report Inappropriate Content
Inventor 2010 user with standard Vault 2010.
Any known bugs when using LOD in Inventor 2010 with the Vault?
Prob. 1.
I have made an .iam file with a lot of subassys in a library, the subass are controlled by Excelsheets. I have Created two Substitue LODs (called "Low" and "Medium") without using "reduced memory mode", so that it will be able to update globally in a more efficient way.
I use this file to copy design from in the Vault to maybe ten copies per project, all used in the same new main assembly for a big layout structure. I have the same LODs in this mainassembly and use "Link all substitute LOD". I Always give every part its uniqe name in the copy design step.
When I change a size in a subass in one of the ten copies i of course want the LOD for this copy to change as well, so that the shape changes in the main layout assembly. I does not do that automatically, and when I push "Update all substitue" it asks if I want to check out the Library assembly file, from which i originally copied from?!?!
Is this a bug, and if so---Does it work if I update to Vault Professional and Inventor 2012?
Problem 2:
I have a Win7, 64 Bit computer, 8GB Ram, Nvidia Quadro 3000M.
When I use LOD, sometimes the models, or part of models just disappear?! I find the individual parts, but when I look in the assembly it has just disappeared?! Like a graphical problem? Sometimes it shows again when I "undo checkout", sometimes not. What causes this problem? is it the LOD function in Invenotr 2010?
