• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Level of Detail (LOD) to show dotted lines?
    323 Views, 10 Replies
    05-31-2012 12:27 AM
    Hello all,
    I ran a few searches and got nothing, I hope I am not duplicating a previously asked question (with thousands of threads out there I probably am)..
    Anyway!
    Could somebody please tell me if Inventor 2010 has the capability of showing certain parts/sub-assemblies in phantom style lines on the idw/dwg file?
    I have a box unit, where I want to show the base, but with the posts  meeting it in phantom.  Then when I do the drawing for the posts, I want the base and roof in phantom.  Then when I do the roof drawing, I want the posts in phantom again.
    I can't change the BOM level as it will apply to every level of detail.  when suppressed, they completely vanish.  Is there a way to do it rather than find the parts in the browser (whilst in the drawing) and change the properties (over-riding them)?
    Thanks in advance.
    Inventor 2012
    Windows 7 64-Bit SP1
    Intel(R) Xeon(R) CPU X5570 @ 2.93GHz
    NVIDIA Quadro FX 3800 (Avail. Graphics Memory 4067MB - Ded. 1024 MB)
    12 GB RAM
    Please use plain text.
    Product Support
    Daniela_Koloszko
    Re: Level of Detail (LOD) to show dotted lines?
    06-06-2012 01:20 AM in reply to: JazzJPH
    Could you please send me an example where you want to change the BOM structure to phantom.
    Daniela Koloszko
    Product Support Specialist
    Autodesk Product Support
    MFG
    Active Contributor
    06-06-2012 01:38 AM in reply to: Daniela_Koloszko
    I have copied and pasted the below message from the email I replied to, just in case the solution helps another member in future.
    "The model I have is too big, and I am not permitted to take time from the project I am working on to produce an example for you.
    Basically I have a steel box frame.  I need it all to be created in one model, however one drawing will show the top frame, another drawing will show the bottom frame while another drawing shows the posts.  I need the posts & bottom frame to be in phantom on the drawing I show for the top.
    I can’t change the BOM to reference as it effects every LOD.
    Does this help at all?"
    So if I have a model that consists of 3 parts (top, middle, bottom), I need:
    • One drawing to show the top, with the middle & bottom not referenced in BOM but shown in phantom
    • One drawing to show the middle, with the top & bottom not referenced in BOM but shown in phantom
    • One drawing to show the bottom, with the middle & top not referenced in BOM but shown in phantom
    These drawings are all taken from the one assembly.  The method I use at the moment is individually selecting the parts in the browser (whilst in the drawing) and changing the properties to make it look phantom.  The item balloons are overwritten because the other parts are still referenced.
    Inventor 2012
    12 GB RAM
    Product Support
    Daniela_Koloszko
    06-06-2012 02:19 AM in reply to: JazzJPH
    Generally the LOD management is used for controlling the memory usage, it removes the parts which are not used in the assembly from the memory so it gives you better performance when you work with Inventor. The LODs do not influence in any way the mass properties or the BOM structure. In order to achieve what you need, you have to use iAssembly. In this way, you can specify different versions of the assembly where the BOM structure of the parts is set to panthom for example. And this will be reflected in the drawing as well.
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1655-Assembli1655/1656-Build_a...
    Daniela Koloszko
    MFG
    Valued Mentor
    06-06-2012 08:58 AM in reply to: Daniela_Koloszko
    I think what he wants is Reference.
    So, you can create an iAssembly with four configurations: one for the whole assembly, and three for the individual parts - each with the other two set as Reference, and then put each configuration on a separate drawing?
    (I know I have cases where detailing a part or subassembly without at least some of the main assembly would not really make any sense when someone looks at it.)
    06-06-2012 09:12 AM in reply to: dan_inv09
    Its much easier to just right click on the parts you want to change to a different line style in the idw model browser and pick "select as edges" then go to the layer dropdown on the annotate tab and pick a different layer that has the line style you wish.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Mentor
    06-06-2012 10:31 AM in reply to: mcgyvr
    If you read all the way to the end:
    "Is there a way to do it rather than find the parts in the browser (whilst in the drawing) and change the properties (over-riding them)?"
    Plus I think the intention may have been to control the Parts List at the same time. (And reference parts don't block what's behind them.)
    06-06-2012 11:00 AM in reply to: dan_inv09
    I read it all.. I just don't see the point in making iassemblies just to control line styles in the idw.. Select the parts once/change line style and be done.
    Windows 7 64 bit
    Valued Mentor
    06-06-2012 11:59 AM in reply to: mcgyvr
    Instead of explaining the method like it was some new idea, you could have said something like, "No, there is not a way to do it rather than find the parts in the browser (whilst in the drawing) and change the properties (over-riding them)."
    And I don't really think it's just about controlling line styles in the idw.
    I think that that was just the way they had come up with to try and show the part in the context of the assembly on the detail drawing, and they would prefer something that does more that just "make the lines dotted".
    06-06-2012 12:10 PM in reply to: dan_inv09
    Well I don't read minds.. I provide an answer based off the information provided in the posts.
    Frankly I don't see why he would even want the other parts as hidden lines and included in a detail drawing for the post or box or whatever.. But thats what he seems to want so I told him the quickest method to do it.
    Windows 7 64 bit
