• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Let a wheel roll in a randomly shaped rail
    212 Views, 5 Replies
    10-24-2012 09:31 AM
    As you can see in the attachment (which is a small test version of my full project) do I have a problem..
    The wheels on the side need to roll inside the guide rail. I can let them roll in each part separately but not in the entire rail.
    I already tried with transitional constrains but then inventor says that there are some problems.
    My project needs to become a sectional gate so there's going te be lots more than just 2 wheels in it...
    Hope someone can explane me how to constrain this movement
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: Let a wheel roll in a randomly shaped rail
    10-24-2012 09:38 AM in reply to: kenevens93
    Try creating a continuous surface (as a seperate part) on the inside of the guide rails.
    Constrain the wheels to this surface instead of the rails.
    Turn the visibilty of the surface off as needed.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    *Expert Elite*
    mrattray
    10-24-2012 09:40 AM in reply to: kenevens93
    Don't double post. It's bad karma..
    hhttp://forums.autodesk.com/t5/Autodesk-Inventor/Constraining-to-a-random-path/td-p/3669326
    Mike (not Matt) Rattray
    Active Member
    10-24-2012 09:44 AM in reply to: kenevens93
    I'm sorry but it did help... He gave me a good tip which i didn't get on the other post...
    Mpatchus: The rail is made by sweeping along a continous axis but in the assembly it always gets divided.. How can i make a continuous surface that wont divided in the assembly?
    Employee
    10-26-2012 01:22 AM in reply to: kenevens93
    Well, I guss you want to get  a animation, I prefer to use Inventor Dynamic Simulation to get such kind movement.
    You can leverage the joint (sliding:Curve & Point), attached please fiind the iam file , I made some changes on your dataset, simpliified the assembly  and modified the guiderail part,  since it requires a close loop.
    Inventor Professional 2013
    Jingyi Liu
    Quality Assurance Team
    Employee
    10-26-2012 01:25 AM in reply to: kenevens93
    Also modified attached part to create a sketch point.
    Jingyi Liu
