Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Let a wheel roll in a randomly shaped rail
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As you can see in the attachment (which is a small test version of my full project) do I have a problem..
The wheels on the side need to roll inside the guide rail. I can let them roll in each part separately but not in the entire rail.
I already tried with transitional constrains but then inventor says that there are some problems.
My project needs to become a sectional gate so there's going te be lots more than just 2 wheels in it...
Hope someone can explane me how to constrain this movement
Re: Let a wheel roll in a randomly shaped rail
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try creating a continuous surface (as a seperate part) on the inside of the guide rails.
Constrain the wheels to this surface instead of the rails.
Turn the visibilty of the surface off as needed.
Inventor 2012 SP1
Vault Pro 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Don't double post. It's bad karma..
hhttp://forums.autodesk.com/t5/Autodesk-Inventor/C
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Mpatchus: The rail is made by sweeping along a continous axis but in the assembly it always gets divided.. How can i make a continuous surface that wont divided in the assembly?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, I guss you want to get a animation, I prefer to use Inventor Dynamic Simulation to get such kind movement.
You can leverage the joint (sliding:Curve & Point), attached please fiind the iam file , I made some changes on your dataset, simpliified the assembly and modified the guiderail part, since it requires a close loop.
Inventor Professional 2013
Jingyi Liu
Quality Assurance Team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Also modified attached part to create a sketch point.
Jingyi Liu
