• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Lego parts in inventor
    585 Views, 13 Replies
    11-08-2012 04:36 PM
    I am designing a robot that combines lego gears/axles with many non-lego parts, and I would like to have everything drawn up in CAD before building it. I have spent my last hour searching google for pre-existing Lego parts compatible with inventor, but my search was not very fruitful.  Does anyone know if these parts exist?
    Thanks!
    Please use plain text.
    Valued Contributor
    Re: Lego parts in inventor
    11-09-2012 12:52 AM in reply to: d3lilley
    If you can't find the parts, why don't you try using iparts to generate the lego bricks.  If you make it so that your table can control the length of the bricks, the width of the bricks, the number of buttons along the length, the number of buttons along the width and the colour, you will be able to generate new variations very quickly.  You should be able to hollow out the bricks and remove the bottom face by using the Shell feature.
    Wayne
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    Valued Contributor
    11-09-2012 01:18 AM in reply to: d3lilley
    http://grabcad.com/library/tag/lego
    Wayne Helley
    Doug_DuPont
    11-09-2012 05:56 AM in reply to: d3lilley
    Here is a I-part Lego Brick. Not Mine copied from someone.
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    Doug_DuPont
    11-09-2012 06:02 AM in reply to: d3lilley
    Here is a I-Part Lego Plate
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    GSE_Dan_A
    11-09-2012 06:08 AM in reply to: Doug_DuPont
    Why did I have to see this thread?!?!? Now I'm going to be playing with virual legos all day instead of doing actual work! :smileyvery-happy:
    GSE Consultants Inc.
    Windsor, ON. Canada
    11-09-2012 07:14 AM in reply to: GSE_Dan_A
    Same reason I clicked the thread :smileysurprised:
    Inventor 2013
    GSE_Dan_A
    11-09-2012 08:34 AM in reply to: sp1n1mbus
    At least its Friday and my boss is a Lego FREAK! I should show him these... Ill probably get asked to build something for him with Legos!
    Windsor, ON. Canada
    Valued Mentor
    swordmaster
    11-09-2012 10:40 AM in reply to: GSE_Dan_A
    lets have a lego building competition
    Inventor 2010 Certified Professional
    Doug_DuPont
    11-09-2012 10:52 AM in reply to: d3lilley
    Here is another
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
