• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    vinzs78
    Learning: creating a wood panel
    183 Views, 2 Replies
    02-01-2012 06:47 PM
    Hi guys,
    I have just started to learn how to use Inventor.... I am loving this software so far but finding difficult to learn on my own.
    I am trying to create a rectangle panel wood with sides with different angles (700x1000mm and thick of 15mm) 2 sides need to be 45degres and the 2 other 25degres.
    I have tried withh the Extrude and taper function ...but this doesn t let me create different angles(taper) on each sides.
    What would be the best way to do this? What other function could i use?
    I hope i was clear enought!
    Thanks in advance
    Please use plain text.
    blair
    Re: Learning: creating a wood panel
    02-01-2012 08:08 PM in reply to: vinzs78
    extrude your profile with square sides, then use the Chamfer command. You could also create a sketch on the side of panel, produce a triangle of the shape of the material you wish to remove and use the extrude command, but with the "cut" option.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    vinzs78
    02-02-2012 08:30 PM in reply to: blair
    Super! thanks Blair....i learned how to use the Chamber command...It is exactly what i need! thanks for the help
