• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    danckm
    Accepted Solution
    Laptop ASUS K55DR for Inventor 2012
    1104 Views, 8 Replies
    11-06-2012 05:46 AM
    Hi everyone.
    I found a laptop
    Asus k55dr
    -CPU:AMD Quad-Core A8 - 4500M - 4 x 1.90 Ghz
    -LCD:15.6" HD Led Backlit (16:9)
    -RAM:2GB DDR3
    -HDD:500GB 5400rpm
    -VGA:AMD Radeon® Mobility™ HD7640G + HD 7470M Dual Graphics with 1GB DDR3 VRAM
    -ODD:8x DVD Super Multi
    -WLAN:802.11 b/g/n GigaLan
    -BATTERY:6 cell (2.52kg)
    -OTHER:VGA WC,2xUSB 3.0, 1XUSB 2.0,VGA-out,Chiclet KB, Card Reader, HDMI, BT
    is it " enough" for running inventor 2012 ( assembly is about 300 part)
    Sory cuz my English.
    Any help is appreciated.
    Thanks all.
    Please use plain text.
    Distinguished Contributor
    Re: Laptop ASUS K55DR for Inventor 2012
    11-06-2012 06:22 AM in reply to: danckm
    64 bit Win7 & min 4Gb ram needed
    Valued Mentor
    Re : Laptop ASUS K55DR for Inventor 2012
    11-06-2012 06:24 AM in reply to: danckm
    Hi
    What is your OS?    32 bit or 64 bit
    i recommand 64 bit with minimum 6 GB ram
    and your HD is to slow try to change it with SSD 256 GB or minimum 7200 rpm
    Yannick Verreault
    Inv. 2012 ultimate
    Inv. 2011 pro sp2
    MS Office 2007
    Win 7 pro, core i7 950, asus P6T WS
    nvidia Gforce GTX 295
    WD caviar black 500Go
    WD caviar black 1To
    Member
    danckm
    11-06-2012 06:48 AM in reply to: danckm
    Thank you for replying.
    I only can upgrade to 6G with ram.the HDD can not be changed.Asus k55dr has no 7200rpm HDD or SSD.
    How about graphic? AMD Radeon® Mobility™ HD7640G + HD 7470M Dual Graphics with 1GB DDR3 VRAM.
    Sr my English :smileyhappy:
    Valued Mentor
    11-06-2012 07:06 AM in reply to: danckm
    Hi
    for your HD you can purchase one and create a copy of the original HD.
    http://www.amazon.com/Mushkin-Direct-Chronos-480GB-Solid-State/dp/B00607H1TU
    I've g74sx and i've installed two SSD
    for the all other stuf it's enough for your works
    Yannick Verreault
    Inv. 2012 ultimate
    Inv. 2011 pro sp2
    MS Office 2007
    WD caviar black 1To
    *Expert Elite*
    sam_m
    11-06-2012 08:37 AM in reply to: danckm
    honestly don't think it would be suitable to work on anything more than a couple small parts.
    2GB ram is way too little, as others have said.
    But the real killer is the screen - according to Asus's website: http://www.asus.com/Notebooks/Versatile_Performance/K55DR/#specifications
    The display is "15.6" 16:9 HD (1366x768) LED Backlight" - so only 768 pixels tall.  You really need a 1080 or more screen to work with Inventor - 768 leaves such a small viewing area it's questionable how much work can be done.  Not to mention some of Inventor's menus are taller than 768 so you won't be able to see the OK or Cancel buttons to click on them...
    as for the graphics card..
    http://www.videocardbenchmark.net/high_end_gpus.html
    the "Radeon HD 7640G + 7470M Dual" scores a pretty bad 526, so it may well struggle with more than a couple parts anyway...  Honestly would doubt how well it would handle assemblies of about 300 parts (assuming they're not all simple square extrusions).  It will probably work and display something, but you'll soon be banging your head against a wall with how slow everything is.
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
    Member
    danckm
    11-06-2012 09:15 AM in reply to: sam_m
    hi, sam_m.thank you fo replying.
    I have a desktop with 1366x768 resolution and can see full tabs.why?
    I'll upgrade to 6G ram.
    According to benchmarks.Radeon HD 7640G + 7470M Dual scores 526 and individual Radeon HD 7640G scores 526 too.what is happening with dual graphics,is there no effect?:smileysad:
    Thanks you!
    *Expert Elite*
    sam_m
    11-07-2012 01:07 AM in reply to: danckm
    in the past laptop users have complained that some option boxes are too large for the screen and they are unable to see some of the buttons.  The System Requirements: http://usa.autodesk.com/autodesk-inventor/system-requirements/ says Inventor needs "1,280 x 1,024 or higher screen resolution" so I can only assume 1024 is the lowest vertical resolution for all the dialog boxes to fit on the screen with all the information.  I run at either 1680x1050 or 19200x1200 so do not know which dialog boxes are bad (or if this issue was fixed a few releases ago).  If you are already working with 1366x768 and are happy with it then fine.
    If the dual Radeon cards work like the dual Nvidia Optimus system then the 2 graphics cards do not work together.  1 is a more powerful gpu for 3d work (and games) and the other is a lower-power 2d card for simple web-browsing or playing videos etc. that won't drain the battery as much.  So any benchmark will only test 1 card at any time, usually the high powered 3d card, which is why the result is the same.
    Member
    danckm
    11-07-2012 01:28 AM in reply to: sam_m
    Thank you so so much Sam.
    Perhaps asus k55dr is not good selection.:smileysad:
    I am student and  have short budget.:smileysad:
    I'll get Laptop Acer Aspire V3 571G.how do you think?
    CPU: Intel® Core™ i5 3210M, 2.50GHz
    RAM: DDR3 6GB
    Hardware: 500GB HDD
    Display: 15.6" HD (1366 x 768 pixels)
    Graphic: NVIDIA GeForce GT 630M, 2GB
    DVD: DVD Super Multi Double Layer
    Weigh: 2.6kg
    Sr about my English.
